(2019-01-03, 15:29)zorg2000k Wrote: [ -> ] (2019-01-03, 09:39)djhifi Wrote: [ -> ]For anyone interested:
Current RC4 is incompatible / doesn't work with the updated version of this skin. It auto-disables it as soon as you enter KODI.
It ran fine up until Leia RC3. RC4 onwards won't work.
Strange, I only just installed a fresh build of RC4 and this skin, working fine for me
I made a typo in the other post (now edited). It's RC5 not RC4
More specifically, this:
kodi-20190102-195fd1cd-master-arm64-v8a.apk
After updating to such version the skin was auto-disabled by KODI on startup.
This will definitely get broken when RC5 gets stable and more people download it.
This can probably be fixed by editing the addons.xml but I was just warning everyone.
Kyo*
Proof from the logs:
Quote:07:32:39.608 T:200536974576 NOTICE: Starting Kodi (18.0-RC5 Git:20190102-195fd1c). Platform: Android ARM 64-bit
07:32:39.609 T:200536974576 NOTICE: Using Debug Kodi x64 build
07:32:39.609 T:200536974576 NOTICE: Kodi compiled 2019-01-03 by Clang 7.0.2 (https://android.googlesource.com/toolchain/clang 003100370607242ddd5815e4a043907ea9004281) (https://android.googlesource.com/toolchain/llvm 1d739ffb0366421d383e04ff80ec2ee591315116) for Android ARM 64-bit API level 21 (API level 21)
07:32:39.609 T:200536974576 NOTICE: Running on NVIDIA SHIELD Android TV with Android 8.0.0 API level 26, kernel: Linux ARM 64-bit version 4.9.109-tegra-g29568bc
07:32:42.985 T:200694285552 NOTICE: ADDON: skin.bello.nero version 7.0.0a is incompatible
Kyo*
All the best in 2019
Please continue with this project.
rc5-2 just got released by Kodi. Skin is auto-disabled again. Now seems to be due to a GUI error.
Kyo*
Quote:22:36:56.818 T:194010637552 NOTICE: Starting Kodi (18.0-RC5 Git:20190112-3cbd6c1). Platform: Android ARM 64-bit
22:37:44.538 T:194244830448 ERROR: EXCEPTION: Unknown addon id 'skin.bello.nero'.
22:37:44.539 T:194244830448 WARNING: Skin Helper Service --> Traceback (most recent call last):
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.skin.helper.service/resources/lib/main_service.py", line 73, in check_skin_version
skin_addon = xbmcaddon.Addon(id=skin)
RuntimeError: Unknown addon id 'skin.bello.nero'.
22:37:44.539 T:194244830448 ERROR: Skin Helper Service --> Exception in resources.lib.main_service ! --> Unknown addon id 'skin.bello.nero'.
22:37:48.613 T:194132133104 ERROR: CAddonInstallJob[skin.bello.nero]: The dependency on xbmc.gui version 5.13.0 could not be satisfied.
22:37:54.540 T:194244830448 ERROR: EXCEPTION: Unknown addon id 'skin.bello.nero'.
22:37:54.542 T:194244830448 WARNING: Skin Helper Service --> Traceback (most recent call last):
22:37:54.542 T:194244830448 ERROR: Skin Helper Service --> Exception in resources.lib.main_service ! --> Unknown addon id 'skin.bello.nero'.
22:38:04.543 T:194244830448 ERROR: EXCEPTION: Unknown addon id 'skin.bello.nero'.
22:38:04.544 T:194244830448 WARNING: Skin Helper Service --> Traceback (most recent call last):
22:38:04.544 T:194244830448 ERROR: Skin Helper Service --> Exception in resources.lib.main_service ! --> Unknown addon id 'skin.bello.nero'.
22:38:05.795 T:194183664880 ERROR: DoWork - Direct texture file loading failed for resource://resource.images.studios.white/Jiangsu TV.png
22:38:06.568 T:194132133104 ERROR: DoWork - Direct texture file loading failed for androidapp://sources/apps/com.plexapp.android.png
22:38:11.264 T:194183664880 ERROR: GetDirectory - Error getting
22:38:12.191 T:194486715632 ERROR: Previous line repeats 6 times.
22:38:12.191 T:194486715632 NOTICE: EMBY.entrypoint.default -> path: ?content_type=video params: {
"content_type": "video"
22:38:12.389 T:194486715632 NOTICE: EMBY.default -> ---<[ default ]
22:38:14.545 T:194244830448 ERROR: EXCEPTION: Unknown addon id 'skin.bello.nero'.
22:38:14.546 T:194244830448 WARNING: Skin Helper Service --> Traceback (most recent call last):
22:38:14.547 T:194244830448 ERROR: Skin Helper Service --> Exception in resources.lib.main_service ! --> Unknown addon id 'skin.bello.nero'.
22:38:17.229 T:194237891824 NOTICE: EMBY.objects.actions -> Play dialog selected.
22:38:19.300 T:194212947184 NOTICE: Previous line repeats 2 times.
22:38:19.300 T:194212947184 NOTICE: EMBY.entrypoint.default -> path: ?mode=reset params: {
"mode": "reset"
Currently updated with Kodi Leia RC5 Git version: 20190113 skin.helper.service does not work.
This addon is necessary for some features of the skin such as some information in movie info etc., it is a problem for the proper functioning of the latter.
Connected to Emby server the correct functioning of the contents for the moment with the appropriate updates works. Greetings
(2019-01-13, 15:44)Kyo* Wrote: [ -> ]Currently updated with Kodi Leia RC5 Git version: 20190113 skin.helper.service does not work.
So the fact that 7.0.1a is auto-disabling itself is related to skin.helper not working with the rc5-2? I have Skin Helper Service version 1.1.25, should I try with .26 alpha from MardukNL repo? (
https://raw.githubusercontent.com/marduk...ngelog.txt) ornot ? I don't understand what you wrote honestly.
Or should I revert back to git version 20190104 ?
What do you mean regarding EMBY? Im aware that I posted some EMBY stuff from the log but my emby for KODI plugin is working fine. It's just the skin that is automatically disabled.
Since you are aware !! in the future it avoids posting misleading posts thanks. Leia version is still in the RC phase and there are good chances and it is also logical that from here to maybe I do not know ...
BelloNero does not work anymore. For my part I try with my chances and with my related "problems" that I am not going to list you to do my best for those who tell you with my heart to want to give to others.
With the version Kodi Leia Git: 20190115 and skin.helper.service 1.1.3 from the original repo BelloNero reports the error but as I said at the time it works it is not disabled.
Quick question regarding PVR Guide.
When oppened on PVR Guide pressing back button will open side menu. Can you change it to close PRV GUIDE instead? There is no way to close Guide. Please
(2019-01-27, 20:32)awesomeultimate Wrote: [ -> ]Hi,
At the moment I'm trying to solve an error, however I try to take a look
Hi, great skin!
I only have a small problem with the PVR channel numbers that are not shown
(2019-02-07, 16:44)alex.junior Wrote: [ -> ]Hi, great skin!
Thanks for the report now is correct.
Hi "Kyo*"
Would you be able to point me out which xml file I have to modify in order to get more channels on the TV guide. At the moment there is only 7 channels within tv Guide
(2019-02-09, 22:57)awesomeultimate Wrote: [ -> ]Hi "Kyo*"
this Views_PVR.xml.
Hi @
Kyo*
How can I turn on colourful Lyrics as per this screenshot? All I get is normal fonts not these fancy ones
(2019-03-03, 18:59)awesomeultimate Wrote: [ -> ]General Options > Select the type of Lyrics
