(2018-05-14, 18:40)luna_s Wrote: [ -> ]Quote:In front of the heatsink we can see the ATX 24 pin power connector where we could install a PicoPSU power source that for now are not compatible with this motherboard.
Is this true ?
Yes, with same PicoPSU unit working fine in my Apollo Lake setup in the Gemini Lake setup don't work... i am waiting for a Asrock response. Maybe a BIOS thing...?
I need to test with more PicoPSU models.... but for now don't work, it's a shame.
Do you have a full 24pin version?
(2018-05-14, 21:24)honcho Wrote: [ -> ]Do you have a full 24pin version?
Yes, i tested with various models similars to this model:
https://www.amazon.com/DC-ATX-160W-Switc...00PI6Q6K4/
This models works with asrock apollo lake motherboards, not with the new gemini lake models... maybe the ddr4, new power states (i don't se differences in the documentation), some bios issue (still v1.0)?...
I tested with 2 different 19V power bricks.
Asrock support informed me the J5005 doesnt support legacy boot so this means installing windows 10 from scratch on an unpartitioned drive or converting the boot partition to UEFI using the following from dos command may work ?
mbr2gpt.exe /convert /allowfulos.
https://docs.microsoft.com/en-us/windows...mbr-to-gpt
Then you should see your sata boot drive in the bios Boot priority options.
(2018-05-14, 20:18)Naismith Wrote: [ -> ] (2018-05-14, 18:40)luna_s Wrote: [ -> ]Quote:In front of the heatsink we can see the ATX 24 pin power connector where we could install a PicoPSU power source that for now are not compatible with this motherboard.
Is this true ?
Thanks, saved me some frustration - was about to recase too!
(2018-05-15, 18:08)luna_s Wrote: [ -> ] (2018-05-14, 20:18)Naismith Wrote: [ -> ] (2018-05-14, 18:40)luna_s Wrote: [ -> ]Is this true ?
Hmm if this is true than this board is POS.
someone already tested it out?
i can confirm picopsu works fine with J4105-ITX board
Also can confirm that a pico psu 150xt works fine with my J4105-ITX
(2018-05-21, 17:22)luna_s Wrote: [ -> ]Also can confirm that a pico psu 150xt works fine with my J4105-ITX
(2018-05-20, 12:44)Nafi Wrote: [ -> ]i can confirm picopsu works fine with J4105-ITX board
With what model exactly? Put a link, please, i want to test it.
