2018-06-02, 17:29
2018-06-02, 19:33
(2018-06-02, 17:29)N01tra Wrote: [ -> ]Use VAAPI, VDPAU is (mainly?) for Nvidia hardware.VDPAU is not for intel. VDPAU is legacy and dead end even on nvidia.
Intel supports VAAPI (they even invented it) ;-)
2018-06-03, 00:12
I wonder why new Ubuntu is configured in a way that VDPAU is used by default and requires manual reconfiguration of these tools (mpv, vlc) to work with VAAPI.
2018-06-05, 21:28
whatever I do after reboot kodi I have to turn off the TV and then turn it on for hdmi signal I do not use windows only kodi I use the j5005 buld i try kernel 16 and kernel 17
2018-06-05, 22:19
2018-06-06, 01:07
2018-06-10, 17:18
(2018-06-05, 22:19)Rumpelstiltskin Wrote: [ -> ]works now reboot no problems see https://forum.libreelec.tv/thread/12626-...raven-apu/(2018-06-05, 21:28)tomtomclub Wrote: [ -> ]whatever I do after reboot kodi I have to turn off the TV and then turn it on for hdmi signal I do not use windows only kodi I use the j5005 buld i try kernel 16 and kernel 17Not depend from kodi, see here
I have the same issue with NUC7PJYH
2018-06-11, 08:20
Hello! Tell me how to lock the j4105 board to output 4K60 on ubuntu 18.04? And then it gives me after a clean installation only 4k30.
2018-06-11, 20:45
(2018-06-11, 08:20)akarpych Wrote: [ -> ]Hello! Tell me how to lock the j4105 board to output 4K60 on ubuntu 18.04? And then it gives me after a clean installation only 4k30.Check xrandr to see if edid is detected correctly?
I have my GLK NUC (NUC7CJYH) with the J4005 working with 4k / HEVC / 10bit (downsampled) with vaapi HW acceleration working (linux 4.17.0 / mesa 1.8.1.1). I compiled kodi from git (f0dc591d40f946b985d0da120b333baecdc8c437). I tried 18 alpha 1 first and it didn't work at all, vaapi all borked on that build for me.
Now trying drm-intel to try get the HDMI issue fixed. For now I have a fix just doing:
$ xrandr --output HDMI1 --mode 1920x1080
$ xrandr --output HDMI1 --mode 3840x2160
That wakes my TV up but it's annoying.
Has anyone got suspend to ram working? It was just crasing for me.
2018-06-12, 08:57
HDMI lost signal just use putty and
mount -o remount,rw /flash
nano /flash/syslinux.cfg
En put in
APPEND boot=LABEL=System disk=LABEL=Storage i915.glkhdmi=2 quiet
Add the command and with crl+o you save it, ctrl+x leaves nano.
type reboot and the system will reboot thats it..
But use libreelec
And clean installatiehttps://my.hidrive.com/share/6iy7g6fgdd#$/Generic
En put in
But use libreelec
2018-07-01, 09:33
Hi, I’ve got a few question.
Bought j5005 and installed win 10 64 bits, worked flawlessly.
1) so now bios 1.3 will solve the HDR issue?
2) how do I flash bios if I don’t have the jumper cap?
3) 4K and HDR, how do it impact? Meaning to say, if I were to stream media from browser would I see the difference? Or, do the source of the file and tv have to be able to output 4K and HDR before I can see the difference?
2018-07-01, 09:42
(2018-07-01, 09:33)1a2a3a Wrote: [ -> ]Hi, I’ve got a few question.1) gemini lake don't support hdr
2) use any metal to short the pins
3) You can check 4K /1080p in youtube
2018-07-01, 09:48
I thought I saw someone mentioning bios 1.3 in ASRock mobo fixed the issue?
If 1.3 doesn’t fixed the issue, essentially I don’t have to flash bios?
So 4K and HDR will only apply if my video source has those? Otherwise it will be pointless yea?
2018-07-01, 10:43
(2018-07-01, 09:48)1a2a3a Wrote: [ -> ]I thought I saw someone mentioning bios 1.3 in ASRock mobo fixed the issue?4K is supported, only not with HDR. So you could still have the benefit of a 4K + HDR video, but converted to SDR. The HDR->SDR conversion must be done by the playback software. DSPlayer+MadVR or MPCHC+MadVR can -theoretically- do it, if the Gemini IGP has enough power for it. Which I guess it does.
2018-07-01, 11:17
Sorry but I’m kinda media idiot here.
You mean with bios 1.3 it solve 4K issue but not HDR issue?
I have a tv model 32LD330 (does this support 4K?)
Do I need a hdmi 2.0 cable?
Assuming the tv don’t support 4K, and I’m using a old hdmi cable(how to check version of hdmi cable?), I wouldn’t be able to watch 4K?
But I have tried watching YouTube 4K and it doesn’t seems to have any issues. I’m still using the old bios
