2018-03-17, 12:05
2018-03-17, 12:14
(2018-03-17, 10:25)Pienoet Wrote: [ -> ]What the any recommended settings to get the temperature below 70 degrees?Removing any plastic casing fully is also a good method for dropping the temp as I experienced.
The FLIRC casing would be another option.
2018-03-17, 12:34
Also worth noting that the Flirc case will soon be shipping with two thermal pads now - with a new one for the 3B+. AIUI the current pads are OK - but because the SoC is a little taller, a slightly thinner thermal pad is preferable.
https://twitter.com/flirc/status/974703162601779201
Quote:Our case is compatible with the new Pi3 B+. Just needs a new thermal pad. They should be ready next week and two pads will ship in all boxes, one for 3B+, and one for older generations.
2018-03-17, 12:36
Got my 3B+ this morning. It definitely feels a bit snappier, and the WiFi improvement is also noticeable. SD MPEG2 with advanced deinterlacing is working really well without the MPEG2 licence key (just as well as ordering them through the Pi Store at the moment is quite challenging... Delete your cookies and don't use the instant PayPal option and you are more likely to be successful with a codec purchase..)
2018-03-17, 12:37
Great news! I’l wait till nect week then😁
2018-03-17, 12:37
With a 3B+ is extra cooling needed if I don't intend to overclock or play H265/HEVC video? HEVC would be nice but in the first instance I won't be bothering as I will still have 1Bs and a 2B on my network. I would like a FLIRC case but I can't find any for sale in the UK at a sensible price.
2018-03-17, 12:51
(2018-03-17, 12:37)speedwell68 Wrote: [ -> ]With a 3B+ is extra cooling needed if I don't intend to overclock or play H265/HEVC video? HEVC would be nice but in the first instance I won't be bothering as I will still have 1Bs and a 2B on my network. I would like a FLIRC case but I can't find any for sale in the UK at a sensible price.
** EDIT : https://thepihut.com/products/kodi-editi...0748229700 would be where I'd get mine ***
These may not have the new pads but £15 inc VAT from CPC Farnell http://cpc.farnell.com/flirc/101219/case...gK5I_D_BwE
£20 on Amazon.co.uk from the Pi Hut https://www.amazon.co.uk/FLIRC-Raspberry...dpSrc=srch with free delivery on Amazon Prime.
However if you aren't playing HEVC content - I'm not sure you'll need one.
2018-03-17, 13:33
(2018-03-17, 12:51)noggin Wrote: [ -> ]Awesome, thank you. I did not realise that you could get them without the Kodi branding.(2018-03-17, 12:37)speedwell68 Wrote: [ -> ]With a 3B+ is extra cooling needed if I don't intend to overclock or play H265/HEVC video? HEVC would be nice but in the first instance I won't be bothering as I will still have 1Bs and a 2B on my network. I would like a FLIRC case but I can't find any for sale in the UK at a sensible price.These may not have the new pads but £15 inc VAT from CPC Farnell http://cpc.farnell.com/flirc/101219/case...gK5I_D_BwE
A question about the FLIRC case. Where do the GPIO cables exit the case?
2018-03-17, 13:48
(2018-03-17, 13:33)speedwell68 Wrote: [ -> ](2018-03-17, 12:51)noggin Wrote: [ -> ]Awesome, thank you. I did not realise that you could get them without the Kodi branding.(2018-03-17, 12:37)speedwell68 Wrote: [ -> ]With a 3B+ is extra cooling needed if I don't intend to overclock or play H265/HEVC video? HEVC would be nice but in the first instance I won't be bothering as I will still have 1Bs and a 2B on my network. I would like a FLIRC case but I can't find any for sale in the UK at a sensible price.These may not have the new pads but £15 inc VAT from CPC Farnell http://cpc.farnell.com/flirc/101219/case...gK5I_D_BwE
I'd always suggest going for the Kodi branded version - as it helps the Kodi foundation - but I can't see them available so easily in the UK.
The Flirc case has a slot in the base that allows a GPIO ribbon cable to exit, however it may be a tight squeeze with some IDC connectors.
2018-03-17, 13:53
Sold out at time of writing, but this s the place to get them in the U.K...
I can vouch for that.... I was greedy and bought two!
2018-03-17, 13:54
(2018-03-17, 13:53)tjay260476 Wrote: [ -> ]https://thepihut.com/products/kodi-editi...0748229700Yes - this is definitely the way to go.
2018-03-17, 14:01
Raspberry Pi 3/libreelec/kodi/Flirc Kodi case.... perfect appliance like system. For me, in the U.K., at least, able to support local and FOSS= awesomeness!!!!
2018-03-17, 14:23
(2018-03-17, 13:48)noggin Wrote: [ -> ]I only have 3 GPIO wires for my Ambilight, so that should be fine. I was hoping for a Kodi branded just so it pays something back. I am considering a case with a built in cooling fan and heatsinks, does anyone have any experience? Something like this...(2018-03-17, 13:33)speedwell68 Wrote: [ -> ](2018-03-17, 12:51)noggin Wrote: [ -> ] These may not have the new pads but £15 inc VAT from CPC Farnell http://cpc.farnell.com/flirc/101219/case...gK5I_D_BwEAwesome, thank you. I did not realise that you could get them without the Kodi branding.
https://www.ebay.co.uk/itm/172972295917
2018-03-17, 16:06
I used to run a Pi 3 in a plusberry pi case with a fan plus heat sinks, and it was prone to overheating. But since switching to the Flirc case it hasn't had a single problem.
Would wholeheartedly recommend them, Jason has made a superb item in that one.
2018-03-17, 20:45
Thanks for all the input. I am going to get the whole kit from Farnell and get the FLIRC case aswell. It makes it a bit more expensive than if I got it from eBay, but I think will be better off in the long run. I will experiment with HEVC and if I can get it reliable I will slowly upgrade all of my RPIs.
