Is it possible to add a query to the mpaa setting from the add-on.
It would be very practical when "skinning" you could do this (see example)
Example:
<value condition="String.IsEqual(Window(Home).Property(themoviedb_python.country_mpaa_setting),de)">$VAR[mpaa_country_de]</value>
Hi, guys. I have a silly question. Is this the default scraper in V19 right now?
(2020-10-26, 09:06)Litcube Wrote: [ -> ]Did it fail some test?
Test? No, we needed to ensure the scrapers were ready for full release before we switched from the original XML scraper to this new Python version.
(2020-11-02, 23:46)Mister XY Wrote: [ -> ]Since the last update of TMDB Scraper Python, i get very often english poster insteade german.
Before you post these types of questions, please check that a German poster actually exists.
Then also provide the links to what you are looking at.
Allstar007
Nothing can be done until the developer looks at the issue. I suggest you download the poster manually and save it in your folder
xml:
HDD
-> Movie name XY (folder)
Movie name XY.mkv
Movie name XY.nfo
Also be aware that filenaming is case-sensitive, so ensure the names are all exactly matched.
(2020-11-03, 02:24)Allstar007 Wrote: [ -> ]Furthermore some movies are not found, although they were found with the old scraper.
Please provide links to a few examples.
(2020-11-03, 02:43)Karellen Wrote: [ -> ]@Allstar007
xml:
HDD
Movie name XY.mkv
Movie name XY.nfo
So I have about 900 films, if I had to change the posters manually only half of them, I would be busy for several days. Which I would have to download the posters and then add them in Kodi. All movies are unnamed with Filebot, with the old TMDB scraper there were no problems.
Among other things, this film Zodiac is not recognized by Kodi.
https://www.themoviedb.org/movie/1949-zo...uage=de-DE
(2020-11-03, 03:14)Allstar007 Wrote: [ -> ]with the old TMDB scraper there were no problems.
Help me understand. If there were no problems with the old scraper, presumably you have your library already created. So did you suddenly come by 900 movies that you have to scrape? or is it fair to say that your 900 movies are all ok, and you only have a couple of new movies affected?
(2020-11-03, 03:14)Allstar007 Wrote: [ -> ]Among other things, this film Zodiac is not recognized by Kodi.
I had no problem scraping that movie. Provide a
Debug Log and I might be able to see why you are having issues with it.
