2021-01-23, 01:56
(2021-01-23, 01:43)sualk Wrote: [ -> ]Another great option would be to set a fallback language for fanart.tv like in Artwork Beef.There is. Check the settings for the scraper.
(2021-01-23, 01:56)Karellen Wrote: [ -> ](2021-01-23, 01:43)sualk Wrote: [ -> ]Another great option would be to set a fallback language for fanart.tv like in Artwork Beef.There is. Check the settings for the scraper.
(2021-01-23, 03:25)Karellen Wrote: [ -> ]Ah, fallback language. Sorry, scanned your post too quickly.
Nope, there is not one, but the developer will see your suggestion above and will decide.
python:xbmc.getInfoLabel("VideoPlayer.IMDBNumber") ## e.g. returns 209112
2021-03-03 15:07:02.537 T:408 WARNING <CAddonSettings[metadata.themoviedb.org.python]>: failed to load value "en" for setting language
2021-03-03 15:07:02.538 T:408 WARNING <CSettingsManager>: unable to read value of setting "language"
(2021-03-03, 04:07)matthuisman Wrote: [ -> ]And bit confused as 1st post says this doesnt work on 19, but it is included with 19...Thanks. I have deleted those comments. They were added in the early days of this scrapers developement.
(2021-03-03, 04:07)matthuisman Wrote: [ -> ]I'm getting MB and MB of the below lines in the log using this scraper on Kodi 19You must have had this installed for quite a while. There were some updates to language codes forced by TheMovieDB. Can you follow this... https://forum.kodi.tv/showthread.php?tid...pid2983546 obviously for this scraper, not the ones mentioned in the post.
Code:2021-03-03 15:07:02.537 T:408 WARNING <CAddonSettings[metadata.themoviedb.org.python]>: failed to load value "en" for setting language
2021-03-03 16:00:07.730 T:491 INFO <general>: initializing python engine.
2021-03-03 16:00:08.007 T:491 INFO <general>: [metadata.themoviedb.org.python]: Find movie with title 'Adventures With Purpose Egypt' from year '2008'
2021-03-03 16:00:13.372 T:491 INFO <general>: CPythonInvoker(2, /usr/share/kodi/addons/metadata.themoviedb.org.python/python/scraper.py): script successfully run
2021-03-03 16:00:13.375 T:491 INFO <general>: initializing python engine.
2021-03-03 16:00:13.381 T:491 INFO <general>: [metadata.themoviedb.org.python]: Find movie with title 'Adventures With Purpose Egypt' from year '2008'
2021-03-03 16:00:18.493 T:491 INFO <general>: CPythonInvoker(2, /usr/share/kodi/addons/metadata.themoviedb.org.python/python/scraper.py): script successfully run
2021-03-03 16:00:18.493 T:490 WARNING <general>: No information found for item 'smb://192.168.20.3/sharedfolders/pool/Movies/Adventures With Purpose Egypt (2008)/Adventures With Purpose Egypt (2008).mp4', it won't be added to the library.
Quote:2021-03-17 15:20:49.741 T:5331 ERROR <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--just non stop errors
Error Type: <class 'socket.timeout'>
Error Contents: The read operation timed out
File "/storage/.kodi/addons/metadata.themoviedb.org.python/python/scraper.py", line 175, in <module>
run()
File "/storage/.kodi/addons/metadata.themoviedb.org.python/python/scraper.py", line 164, in run
enddir = not get_details(parse_lookup_string(params["url"]), params['handle'], settings)
File "/storage/.kodi/addons/metadata.themoviedb.org.python/python/scraper.py", line 102, in get_details
imdbinfo = get_imdb_details(details['uniqueids'])
File "/storage/.kodi/addons/metadata.themoviedb.org.python/python/lib/tmdbscraper/imdbratings.py", line 34, in get_details
votes, rating, top250 = _get_ratinginfo(imdb_id)
File "/storage/.kodi/addons/metadata.themoviedb.org.python/python/lib/tmdbscraper/imdbratings.py", line 38, in _get_ratinginfo
response = api_utils.load_info(IMDB_RATINGS_URL.format(imdb_id), default = '', resp_type='text')
File "/storage/.kodi/addons/metadata.themoviedb.org.python/python/lib/tmdbscraper/api_utils.py", line 62, in load_info
response = urlopen(req)
File "/usr/lib/python3.8/urllib/request.py", line 222, in urlopen
File "/usr/lib/python3.8/urllib/request.py", line 525, in open
File "/usr/lib/python3.8/urllib/request.py", line 542, in _open
File "/usr/lib/python3.8/urllib/request.py", line 502, in _call_chain
File "/usr/lib/python3.8/urllib/request.py", line 1397, in https_open
File "/usr/lib/python3.8/urllib/request.py", line 1358, in do_open
File "/usr/lib/python3.8/http/client.py", line 1347, in getresponse
File "/usr/lib/python3.8/http/client.py", line 307, in begin
File "/usr/lib/python3.8/http/client.py", line 268, in _read_status
File "/usr/lib/python3.8/socket.py", line 669, in readinto
File "/usr/lib/python3.8/ssl.py", line 1241, in recv_into
File "/usr/lib/python3.8/ssl.py", line 1099, in read
socket.timeout: The read operation timed out
(2021-03-17, 17:28)dm21912 Wrote: [ -> ]Longer log extract https://cloud.dimspace.xyz/s/W6mS4eAdcZ2FAwQOh geez,, what a terrible site. Please use Kodi Paste Site and post the full log thanks.
(2021-03-17, 20:26)Karellen Wrote: [ -> ]you dont even know what nextcloud is? its my personal file host on my home server, it was quicker and easier to just use that as the pertinent parts of the log was already here in text (md) form and the kodi log uploader in matrix does not work, it crashes every time you try to use it.(2021-03-17, 17:28)dm21912 Wrote: [ -> ]Longer log extract https://cloud.dimspace.xyz/s/W6mS4eAdcZ2FAwQOh geez,, what a terrible site. Please use Kodi Paste Site and post the full log thanks.
(2021-03-18, 00:51)dm21912 Wrote: [ -> ]it looks no different https://paste.kodi.tv/ufegipukol.kodi just has pretty colours..Haha, you are joking, right?
(2021-03-27, 07:56)sirmedia Wrote: [ -> ]it gets stuck at 50% and if I try to exit Kodi while it's running it just locks up, I have to force kill Kodi (on Android, Chromecast with Google TV to be exact). The database also ends up with duplicates, same movies shows up as 1080p and 480 SD even though there is a single file. Any settings I should be checking? I tried reinstalling Kodi and starting clean and it does not help.We'll need a Debug Log that captures the problem you describe.
