2021-10-24, 20:56
2021-10-24, 20:59
As it's a Sunday and we're volunteers, submission to Store won't happen until tomorrow, then it's up to MS. However this time we've pushed the binaries to our mirror servers ( the location I linked above) so those who are impatient and know how to sideload can do so.
2021-10-27, 16:46
It's now available!
Gonna uninstall and reinstall my addons though.
2021-10-27, 17:19
(2021-10-27, 16:46)tutu Wrote: [ -> ]It's now available!
I just uninstalled and reinstalled, it is v 19.3 Matrix indeed
The issue I now have is that I am unable to connect to the Kodi Official Repository. Same error I was getting on 18.9. Anyone else?
2021-10-27, 17:37
So I've uninstalled Kodi, reinstalled Kodi 19.3, tried to install a single add-on but I am getting an error.
I've installed kodi log viewer to see what the issue is:
I am getting this error:
ERROR <general>: EXCEPTION Thrown (PythonToCppException): --> (snip)
Permission denied: 'S:\\Program Files\\WindowsApps\XBMCFoundation.Kodi_19.3.0.70_x64__4n2hpmxwrvr6p\\system\\pyth
(snip)
File
"Q:\Users\UserMgr0\AppData\Local\Packages\..
I can't paste the rest as Kodi Logfile Uploader wont work probably for the same issue!.
Is there another way to get the error log?
PS I can connect to the official kodi repo.
(snip)
File
2021-10-27, 21:05
I just installed Kodi Matrix 19.3 on my Xbox Series X from official Microsoft Store.
I'm now able to play a 4k video without crashes
I downloaded, installed and configured Kaster Kodi Addon without problem.
But the screensaver failed to start.
Not able to see the log at this moment.
My "existing kodi database" seem to have some problems playing my videos.
If i add a new Video Source for the same video, everything is fine!
Perhaps something not working as expected when Kodi did the "database migration" from 18.9 to 19.3.
Not a problem for me.
Will check for logs soon.
2021-10-28, 03:27
For Kodi Music/Video problem:
If i upgrade an existing Kodi installation from 18.9 to 19.3 from Microsoft Store:
- All existing video in my library are not playing.
- If i play the sames videos using DLNA (upnp) which doesnt use Kodi Database to read last play times, personal infos, etc. Everythings is playing fine. No 4k video crashes.
If i uninstall Kodi and reinstall 19.3 clean from scratch from Microsoft Store:
- All videos and music i add in my new library are playing fine
- No 4k video crashes
- Default tone mapping for HDR video is working fine (colors are fine)
- Interface is now at 4k
- I'm now able to use Milkdrop2 visualizations at 4k without crashes
- Playing from Secured SMB Shares is working fine
For Kodi Add-ons problem:
I just tried the exact same Kodi UWP 19.3 release (msix extracted directly from Microsoft Store) in Dev Mode as App.
No problem with add-ons.
I remember i tested the same add-ons with Kodi 19.1 in Dev mode and it worked too.
I saw this on Microsoft Store.
It's strange..:
https://ibb.co/3vX6zkZ
My Python error for problematic add-ons is the same as other published logs in Kodi Xbox forum:
https://forum.kodi.tv/showthread.php?tid=365157
Even with a clean 19.3 Microsoft Store Install, i have the Python error when i try to use an add-on downloaded and installed from Kodi interface.
I'm able to download and install them but I'm not able to use them.
Conclusion
On my side, I'm happy with this Kodi release
I'm NOW able to play all my videos and music without problem.
It was not the case with Kodi 18.9.
For sure, i can provide help for Kodi addons problem in next weeks if necessary.
Its a problem that affect a lot of users.
The big problem here.. i'm NOT able to reproduce the problem with the same code running in Dev mode..
How can we provide a public fix if we are not able to test it first?
It's strange..:
Conclusion
2021-10-28, 11:59
Vi, did install the 19.3 Kodi on the Xbox Series X but when i try to use TVheadend Adson, 1/2 seconds after i select a Channel the Xbox Will shutdown.
Someone with the same problem?
2021-10-28, 18:22
(2021-10-28, 11:59)Jmoportugal Wrote: [ -> ]Vi, did install the 19.3 Kodi on the Xbox Series X but when i try to use TVheadend Adson, 1/2 seconds after i select a Channel the Xbox Will shutdown.
Yes i have THE exact same issue
2021-10-28, 19:54
(2021-10-28, 18:22)Pienoet Wrote: [ -> ](2021-10-28, 11:59)Jmoportugal Wrote: [ -> ]Vi, did install the 19.3 Kodi on the Xbox Series X but when i try to use TVheadend Adson, 1/2 seconds after i select a Channel the Xbox Will shutdown.
For what i could see it isn't a new bug/problem
https://forum.kodi.tv/showthread.php?tid=359223
2021-10-28, 20:44
(2021-10-28, 03:27)Chicopower Wrote: [ -> ]For Kodi Music/Video problem:You can compile and upload kodi to the ms store and set to private audience and test it while in retail mode
It's strange..:
Conclusion
2021-10-28, 21:05
(2021-10-27, 21:05)Chicopower Wrote: [ -> ]I just installed Kodi Matrix 19.3 on my Xbox Series X from official Microsoft Store.Do you have an option to enable audio passthrough?? Because I dont have it. My connection: XBOX series X -> Pioneer vsx 1131
Unfortunately i cant have DTS HD Master, Dolby TruHD. Instead i have only PCM (
2021-10-29, 00:44
(2021-10-28, 20:44)Hitman24 Wrote: [ -> ]Thx for your technical infos! Good idea!(2021-10-28, 03:27)Chicopower Wrote: [ -> ]For Kodi Music/Video problem:You can compile and upload kodi to the ms store and set to private audience and test it while in retail mode
It's strange..:
Conclusion
I don't have any problem if someone fix it behind scenes. I will be happy!
I have an idea on how we can perhaps fix this issue.
I will give it a try.
2021-10-31, 13:38
(2021-10-28, 19:54)Jmoportugal Wrote: [ -> ](2021-10-28, 18:22)Pienoet Wrote: [ -> ](2021-10-28, 11:59)Jmoportugal Wrote: [ -> ]Vi, did install the 19.3 Kodi on the Xbox Series X but when i try to use TVheadend Adson, 1/2 seconds after i select a Channel the Xbox Will shutdown.
if you turn off harware accelaration it plays fine with some microstutters.
So i think it cant hardware decode live tv streams.
2021-10-31, 16:18
Im not getting HDR images, I mean, my HDR contents are playing as SDR in my Series S.
Im doing something wrong or HDR is just not ready yet?
