2021-06-07, 19:45
2021-06-07, 21:04
Good to hear. Do you have a build I could also test?
2021-06-07, 21:27
Hi Hitcher,
You can use my kodixbox 23.0.15.0 msix UWP x64 here:
https://1drv.ms/u/s!Am4la0djZrU4gQq3ZxZr...0?e=fH0UV6
Just forget the mentioned 23.x of the file (i use this version 23 to be sure i don't overwrite my other Kodi tests deployed on my Xbox).
My 23.0.15.0 is the 19.1 matrix version with master branch code.
You can see my pull request here:
https://github.com/xbmc/xbmc/pull/19861
2021-06-14, 16:05
Hello, long time lurker and user of Kodi.
Just wanted to ask is there still a need for testing on Xbox Series X?
I wanted to ask before paying to get the developer account to sideload the app.
2021-06-14, 18:01
Not really. I've got a Series S for testing purposes now.
2021-06-15, 08:32
(2021-06-14, 18:01)Hitcher Wrote: [ -> ]Not really. I've got a Series S for testing purposes now.
That's nice to hear. I'm ready to test in the future if needed.
Any idea when 19.1 will be back on the store?
2021-06-15, 08:39
(2021-06-15, 08:32)spooknik Wrote: [ -> ]Any idea when 19.1 will be back on the store?
I think the plan will be a release for v19.2.
2021-06-17, 17:38
2021-06-17, 18:59
(2021-06-17, 17:38)Aisen Wrote: [ -> ]It's sad that a critical bug took such a low priority to be solved.
It's not that it's low priority but a lack of Windows devs.
2021-06-19, 09:54
can you check the TVHeadend client? it craches the xbox SX completely by just powering off after 3 seconds Video.
2021-06-27, 06:44
Will HDR work on series S on Kodi with the upcoming 19.2 release?
2021-06-27, 10:14
(2021-06-27, 06:44)ozkhan1 Wrote: [ -> ]Will HDR work on series S on Kodi with the upcoming 19.2 release?Unfortunately we haven't found a way to get it working on the Xbox.
2021-06-27, 15:14
(2021-06-27, 10:14)Hitcher Wrote: [ -> ](2021-06-27, 06:44)ozkhan1 Wrote: [ -> ]Will HDR work on series S on Kodi with the upcoming 19.2 release?Unfortunately we haven't found a way to get it working on the Xbox.
It’s strange but I compared the quality of a few files I played on Apple TV and x box one s side by side and they looked identical in quality… yes the HDR flag was not coming on, I acknowledge that but maybe it’s my eyes that don’t perceive the difference or perhaps my tv which was upscaling it pretty well.. not sure.
2021-06-29, 16:38
Just to see if I got it straight.
Kodi 19.2 will be released to the XBox store, and it will support playing 4k content?
If so, is there an expected version release date?
2021-06-29, 18:42
(2021-06-29, 16:38)Dr. MaNiAk Wrote: [ -> ]Kodi 19.2 will be released to the XBox store, and it will support playing 4k content?
Hopefully, yes. No ETA.
