i think i got further but not there yet;
# Run "/usr/share/doc/bluez/examples/list-devices" to verify that the remote is paired (and connected).
Output;
(T: XBMCLive)root@XBMCLive:/home/temp/bdremotescript# /usr/share/doc/bluez/examples/list-devices
[ /org/bluez/3022/hci0 ]
Name = BlueZ
Powered = 1
Devices = dev_00_24_33_98_D2_E3
DiscoverableTimeout = 180
PairableTimeout = 0
Discoverable = 0
Address = 00:0A:3A:72:B6:B7
Discovering = 0
Pairable = 1
Class = 655620
[ /org/bluez/3022/hci0/dev_00_24_33_98_D2_E3 ]
Name = BD Remote Control
Paired = 0
Adapter = /org/bluez/3022/hci0
Alias = BD Remote Control
Connected = 0
UUIDs =
Address = 00:24:33:98
2:E3
Class = 0x00250c
Trusted = 1
* Seems very postive to me
Also, running "cat /proc/bus/input/devices | grep emot" should show the remote.
Output;
(T: XBMCLive)root@XBMCLive:/home/temp/bdremotescript# cat /proc/bus/input/devices | grep emot
* Its not there, i listed without grep to make double sure, this does not have a positive result
# At this point, the remote should connect (and auto-disconnect after a timeout, if configured). The d-pad is probably the best way to test it within xbmc. If you have a terminal active, pressing the number buttons should type the number.
Q: loading the module trough /etc/modules is enough to get all of this working after reboot? No repairing, or starting of any other script necessary?
I hope we can solve my problem,
THnx so far for your updates!
