I need this information for the plugin 'trakt utilities'
http://forum.xbmc.org/showthread.php?tid=98582..
It synchronise the movie library with the trakt service, so i can see all my movies in internet..
To recognize the movie it look for the imdb id..
So with mymovies scraper it can't recognize all of my movies..
If it's possibile to add this information?
My last comment is in moderation...:/
However i use trakt, an Xbmc plugin to synchronise my movies with trakt service..so i can see my film library in internet..It use imdb it to' identify the movie..
You can see the imdb id in the export and in the database c09.
Tell me if you want support or test file..
I know trakt...but never use.
c09 is a column of movies table of xbmc databse...i suppose i sqllite but i don't know where is and what use for see it...can you explain me?
You have to connect to Xbmc db..it's in the user data folder..
To connect to db i use SqlliteSpy..once open the db you can scan the movie table and search the movie without the id..Now i look for the query to launch and i post here..
Edit: i don't have access to my db now but it should be 'select * from movie where c09 = ''
So it show the movies without imdb id..
Have you got time to see if is possible to add this feature?
If you want I can help you..
Grazie mille
Tmac12 Wrote:Have you got time to see if is possible to add this feature?
Grazie mille
Give me some days, i'm enough busy...
For help you can test the realease...when it's ready
Ciao!
Grazie mille
try this version:
http://mymovies-xbmc-scraper.googlecode....v1.1.9.zip
...and report your feedback.
I remember you that is no perfect: not always the scraper can get the correct imdb id...this because there is not user interaction for find film name on imdb database, it's "automatic".
Instead for mymovies.it film db the user can interact with a short list of possible film that match with file name.
I think I was not clear
Ciao!
Ok!!I Will try it this evening..
Yes, i've understand..
Grazie mille!!
Wonderful!!
It works...I've try some movies and it update the information of imdb in the database...
Very well...in my test only 1 film dont't have the correct information, but as you said I can switch the Movie only for mymovies.it...
Great job!!
Grazie
Tmac12 Wrote:Wonderful!!
Great job!!
Grazie
Good!
I think you just know, but for the film that don't find correct imdb you can use:
http://wiki.xbmc.org/index.php?title=Imp...ML_and_URL
and set only <id></id> tag
Ciao!
Released version 1.1.9:
Changelog:
- Added imdb id, not visible in film info but needed for trakt plugin (Tmac12 request)
Could be set the scraper to display movies title in english rather than in Italian?
Quote:Could be set the scraper to display movies title in english rather than in Italian?
Ciao,
mymovies.it don't have always original title...and this is italian scraper
If can i ask, why you want this feature?
Because more and more movie titles, especially "recently", are translated senseless!
So, would very nice if this scraper could find the original movie name and dispay it, keeping the rest (trailer, reviews, etc.) in Italian.
