Hi all,
Long time follower, first time poster here...
I swear I had updates disabled on my aTV, but obviously something didn't work here, and I'm left with a 'standard' (close to useless) box!
MaestroDD Wrote:1) "patchstick" the 3.0 ATV
I no longer had a patchstick available, but followed the instrcutions from
PatchStickBuilder and once again have SSH access.
MaestroDD Wrote:2) ssh into it and download Launcher-3.2.alpha1-debug.run
This URL seemes to be old, and I ended up finding and using the newer one from here:
http://atv-xbmc-launcher.googlecode.com/...-debug.run
MaestroDD Wrote:3) install Launcher chmod +x Launcher.. ; ./Launcher-3.2...
Check... Easy enough
MaestroDD Wrote:4) install XBMC with Launcher or just re-symlink your old install (ln -s /Users/frontrow/Applications/XBMC.app /Applications/XBMC.app)
Launcher wasn't there (See below) so I've tried this symlink as well...
MaestroDD Wrote:5) test
... And this is where I go wrong.
I should note, that following the PatchStickBuilder I have a new AppleTV menu item "Launch More!" This has four sub menu items (Applications, Scripts, Settings and About) NONE of which actually work.
When I click on them, I get the click sound, but absolutely nothing happens.
Even after completing all of the steps discussed in this thread, I still do not have any other new menu items.
How can I:
a) Fix / Delete the Launch More! menu item?
b) Add the Launcher item, so I can get to XBMC?
... Or simply c) Manually edit the menu items myself via SSH?
Any help would be appreciated!
