2009-11-08, 18:48
2009-11-08, 19:04
The error message appears when I select XBMC (9.04.1 or 9.11 alpha1) from the "Launcher downloads" menu.
The Boxee download seem work correctly, but the app don't start...
Shud I try to download the app from the XBMC site and manually install it on atv via ssh?
Thanks all for help!
2009-11-08, 19:07
maxroncali Wrote:The atv error message reported also by anamika, mrjekill, Bazilatfx, larryim:
"Click play/pause to restart".
please make sure you're using Launcher-3.2.beta3
If the error still comes up, pastebin console.log and crashreporter.log
2009-11-08, 19:34
Beta 3 was the fix; did not need to rebuild entire ATV; just re-run Beta 3
2009-11-08, 19:46
MaestroDD Wrote:please make sure you're using Launcher-3.2.beta3
I've beta3 installed.
Here is the console.log:
http://docs.google.com/Doc?docid=0ATD0gm...N2M3&hl=en
No crashreporter.log file in my atv. Sorry!
2009-11-08, 20:30
Amet Wrote:Beta 3 is working on 3.0.1
Thanks MaestroDD
Zeljko
Worked for me. Thanks
2009-11-08, 20:40
maxroncali Wrote:I've beta3 installed.
log looks like this is beta2. Please re-check if this is beta3 (Launcher -> About) or just might want to just reinstall beta3
2009-11-08, 21:01
Spoke to soon. Initially everything looked fine; Launcher works, but XBMC is acting up.
I installed the latest Alpha, it launched and I was able to navigate and play stuff etc. But the interface was screwed-up in places, so I decided to downgrade XBMC to the previous version.
Now, I'm able to launch XBMC (previous version) but it shows in a window within a window i.e. I can see the outer window with the red and green buttons in the top left, and XBMC is running within in another window with its own red, green button. Additionally this inner window is not full screen it is quarter screen (half height, half width).
What's going on!
What's going on!
2009-11-08, 21:15
anamika Wrote:Spoke to soon. Initially everything looked fine; Launcher works, but XBMC is acting up.
What's going on!
I suggest you open a new thread about it as his is a thread about Launcher, which in your case works.
anyway you will need to post debug log, post it and I am sure someone will be able to help.
one thing you can try is remove/backup your /Volumes/frontrow/Library/Application Support/XBMC and re launch XBMC
Zeljko
2009-11-08, 21:37
Amet Wrote:[...]
keep in mind, that Launcher adds/updates advancedsettings.xml in ~/Library/Application Support/XBMC/userdata/ which is needed (it adds <osx_gl_fullscreen>true</osx_gl_fullscreen>). If it's no present, XBMC will have problems gettings in front of Finder.
Can easily be fixed by reinstalling XBMC through Launcher...
2009-11-08, 21:39
all,
managed to connect to ssh on the atv box and execute the commands, it's just not working for me (see output from the ssh window below)
any bright ideas, tips etc.......
james
login as: frontrow
Welcome to the AppleTV (via atv-usbcreator)
[email protected]'s password:
-bash-2.05b$ wget http://dl.getdropbox.com/u/858897/XBMC/L...-debug.run
--19:34:10-- http://dl.getdropbox.com/u/858897/XBMC/L...-debug.run
=> `Launcher-3.2.alpha1-debug.run'
Resolving dl.getdropbox.com... 174.129.42.248
Connecting to dl.getdropbox.com|174.129.42.248|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: http://dl.dropbox.com/u/858897/XBMC/Laun...-debug.run [following]
--19:34:16-- http://dl.dropbox.com/u/858897/XBMC/Laun...-debug.run
Resolving dl.dropbox.com... 75.101.148.191, 174.129.33.159, 174.129.212.16, ...
Connecting to dl.dropbox.com|75.101.148.191|:80... connected.
HTTP request sent, awaiting response... 404 NOT FOUND
19:34:16 ERROR 404: NOT FOUND.
-bash-2.05b$ chmod +x Launcher-3.2.alpha1-debug.run
chmod: Launcher-3.2.alpha1-debug.run: No such file or directory
james
login as: frontrow
2009-11-08, 21:46
lynbury: well, either the download is down (try with a browser) or wget chokes on some redirection. Try ownloading with a browser and then copy it to the atv for example via scp.
2009-11-08, 21:47
lynbury Wrote:all,
james
login as: frontrow
you are trying to download alpha 1 , Launcher is on beta 3 now....
2009-11-08, 21:48
2009-11-08, 21:48
nice 2 replies in under 1 minute
