magnetism Wrote:Ok, so when you type makemkvcon in the commandline it works. Hmmm, strange. I don't see anything wrong in the logs. It creates the right command to start stream an inserted blu ray disc.
How long did you wait before killing XBMC?
makemkvcon
makemkvcon: error while loading shared libraries: libmakemkv.so.1: cannot open shared object file: No such file or directory
there seams to be something wrong...
EDIT:// I think I found the problem I forgot to also install the makemkv_v1.6.3_oss.tar.gz. Doing it now.
EDIT2 :// Works now perfectly. Is there a possibility to make it faster? Less precaching?
No,at least not in xbmc . It makemkv that is slow cause it's parsing all items on the disc.
btw. will all the blurays work or are there any limitations?
i want play my blueray disk so i download
http://www.bultsblog.com/plugin.makemkvbluray.zip addons and install.
but have to do something else?
i try to go to bluray addon and play blueray disck but when i start play the system dont respond me keyboard and mouse don't work all i have to do is reboot from restart button from my case
Did you read the first post of this thread?
Tried to play my Avatar 3d iso and it loaded up to 100% then failed.
Log:
http://pastebin.com/xJUftx3S
I am running the most current of the script and the most current version of makemkv.
Phantisy Wrote:Tried to play my Avatar 3d iso and it loaded up to 100% then failed.
Log: http://pastebin.com/xJUftx3S
Nothing in the logs that suggests failure. Can you try from the command line:
"makemkvcon" stream iso:/mnt/Movies0/AVATAR_3D.iso
let me know what the output is. If it seems to start the streams successfully, can you try to play them in xbmc then?
i only have 1 iso that wont play natively and its bluray. all i needed to do was mount the iso with the following command:
mount -o loop -t udf pathtobluray.iso /media/cdrom
i used /media/cdrom, but i think it could be any arbitrary mount point, just make sure the folder exists
then on xbmc just browse to the mount point(local or smb works), and find the largest m2ts file and it should play just fine without the use of makemkv.
optional: you can go one step further if you want to, copy the correct m2ts file to your video folder (noting the name), then delete the iso file. what your left with is a video file that xbmc will natively play without any headaches
yep ... I guess a iso without any drm protection can be played without any problem .-)
Insert a native bluray into the drive and this disc will not play.
I have an issue with the latest plugin (for the current stable of xbmc)
I can use the script to play ISO's and index.bdmv files. I however can't play discs.
The script starts up makemkvcon with all it's stuff properly. I can see in the log file that it eventually starts up the upnp server, but the script just stops. It also does not show the small waiting window with the countdown. I have been going over the code a few times, and I don't understand it myself....
In essence I have the same issue as Pigeta.
Xsession: X session started for lennard at Tue Jan 11 15:45:41 CET 2011
makemkvcon: no process found
/bin/sh: taskkill: not found
MakeMKV v1.6.3 linux(x86-release) started
Debug logging enabled, log will be saved as /home/lennard/MakeMKV_log.txt
DEBUG: Code 0 at mmS9Y-kHPL%IVQ'XE ET:213130122
Using direct disc access mode
File 00001.mpls was added as title #0
File 00080.mpls was added as title #1
File 00081.mpls was added as title #2
File 00082.mpls was added as title #3
File 00083.mpls was added as title #4
File 00084.mpls was added as title #5
File 00086.mpls was added as title #6
File 00002.mpls was added as title #7
File 00003.mpls was added as title #8
File 00004.mpls was added as title #9
File 00085.mpls was added as title #10
File 00087.mpls was added as title #11
File 00088.mpls was added as title #12
File 00090.mpls was added as title #13
File 00091.mpls was added as title #14
File 00092.mpls was added as title #15
File 00093.mpls was added as title #16
File 00094.mpls was added as title #17
File 00096.mpls was added as title #18
File 00095.mpls was added as title #19
File 00098.mpls was added as title #20
File 00097.mpls was added as title #21
Title #00000.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00083.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00442.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00450.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00504.m2ts has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00506.m2ts has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00507.m2ts was added as title #22
Title #00508.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00509.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00510.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00511.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00512.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00513.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00514.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00515.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00516.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00517.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00519.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00520.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00528.m2ts has length of 116 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00536.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00537.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00538.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00539.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00540.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00541.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00558.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00561.m2ts was added as title #23
Title #00562.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00563.m2ts was added as title #24
Title #00564.m2ts has length of 67 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00725.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00726.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00727.m2ts has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00728.m2ts has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00729.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00730.m2ts was added as title #25
Title #00731.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00732.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00733.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Operation successfully completed
Streaming server started, web server address is http://192.168.25.3:51000 or http://localhost:51000
UPnP server enabled on address 192.168.25.3
EDIT:
As a sidenote... I can execute it manually:
makemkvcon stream disc:0
http://192.168.25.3:8080/xbmcCmds/xbmcHttp?command=PlayFile(http://192.168.25.3:51000/stream/title0.m2ts;1)
So the disc is okay.
EDIT 2:
I can work with "Browse Disc" so at least I can actually view my discs ;-)
So, let me get this straight. It works with browse, you can actually select a title and play? But if you select play disc it doesn't work?
linuxluemmel Wrote:for a 64 bit system :
http://swiss-army-knife.googlecode.com/files/makemkv-swiss-army-knife-64-12-19-2010.tar.gz
Just installed your .deb package for makemkv. One question: Does it automatically download all the *.svq packages, as it says in their website? I don't see any .svq files at all in my system. Am I missing something? Cheers!!
magnetism Wrote:Now also available as an addon
Install from zip. Follow all other steps to get makemkv etc...
Tried the plug-in "Install from zip file" but it failed to install, returning the error: "Installation failed". Here is the log -
http://pastebin.com/McsrYF1a
Can anyone please tell me if anything I'm doing wrong? Spec., version of XBMC etc. all in my signature. cheers!!
MacUsers Wrote:Tried the plug-in "Install from zip file" but it failed to install, returning the error: "Installation failed". Here is the log - http://pastebin.com/McsrYF1a
Can you try to unzip it yourself in the addon directory?
