2011-02-03, 06:51
dazex Wrote:rflores2323,
There are two different drivers that need to be installed upon connecting the ATV2 to your computer: iBoot and DFU
In regular iBoot mode, let Windows discover the driver and install the proper software for it.
When in DFU mode, Windows will install a different driver.
I know if you actually click on the system tray prompt, you will actually see if your ATV is in iBoot mode or DFU mode. Kindda a handy feedback IMHO.
So in summary, there are two distinct drivers. Let Windows install the pertinent drivers for them. It should only need to happen once.
If iTunes launches, it will not automatically restore anything. You have to manually allow it to. If you don't want iTunes to autolaunch upon insertion of the ATV2, you need to kill the iTunesHelper.exe process.
It's possible that you may need to install iTunes in order for Windows to have the drivers it needs to see the ATV2.
ok I downloaded the drivers and got my atv2 to boot into dfu mode. I then ran the exploit waiting till it finished and the uplugged the usb and hooked up the hdmi. nothing...
got this in the command terminal (tried it twice)
what am I doing wrong. the light is blinking on the atv and I just get an apple on my screen.
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Richard Flores>cd desktop/tethered
C:\Documents and Settings\Richard Flores\Desktop\tethered>tetheredboot -i iBSS.k
66ap.RELEASE.dfu -k kernelcache.release.k66
Initializing libpois0n
'TASKKILL' is not recognized as an internal or external command,
operable program or batch file.
Waiting for device to enter DFU mode
Device must be in DFU mode to continue
Found device in DFU mode
Checking if device is compatible with this jailbreak
Checking the device type
Identified device as AppleTV2,1
Preparing to upload limera1n exploit
Resetting device counters
Sending chunk headers
Sending exploit payload
Sending fake data
Exploit sent
Reconnecting to device
Waiting 2 seconds for the device to pop up...
Uploading iBSS.k66ap.RELEASE.dfu to device
[==================================================] 100.0%
Waiting 10 seconds for the device to pop up...
Uploading kernelcache.release.k66 to device
Exiting libpois0n
Sending fake data
Exploit sent
Exiting libpois0n
