2016-10-16, 11:16
2016-11-11, 17:26
While 2.34 *does* show collections, their "Next page" link always shows the same first page again.
2016-11-11, 19:26
yup next page is broken all through app hope someone can fix thanks
2016-11-13, 15:56
OK so *inside* a Collection, the "Next" button doesn't work
I will probably only have time to look in a week or two. Unless someone sends a pull request
2016-11-14, 03:26
The collections page is actually dumping the whole lot of video in the collection in one page. The Pagination you see on the webpage is actually done within the style sheet ( you can see that it only pulls one page and then for any further page it is referred within the same page with #)
I have done a fix but that involves no pagination and lists all the videos in the collection in oneshot. Have done a pull request for dquaid to analyse and approve
2016-12-10, 18:47
It has stopped working on both my Android boxes. Is it only me or it is a general failure?
2016-12-11, 18:03
Yes I can confirm that Fantasti.cc doesn't work anymore, at all since Version 2.3.36
Version 2.3.35 was the last working version, also with the fix that dumbed all contents of one category one single page
I have downgraded to http://ftp.bit.nl/mirror/pub/superrepo/v...2.3.35.zip
and it works again.
I have also disabled "Auto Update" on the add-on.
and it works again.
2016-12-14, 02:14
Fixed in 2.3.37
2016-12-16, 21:19
Thanks for fixing!
Sent from my p8000
Sent from my p8000
2016-12-22, 18:57
(2016-12-14, 02:14)dquaid Wrote: [ -> ]Fixed in 2.3.37
Any chance a feature either to save search terms locally, or save the last search term last typed in, instead of having to re-type search terms from scratch? A saved search bookmark folder would be nice to not have to re-type your search terms too.
2017-10-25, 15:46
Updated to 2.3.39
A few bugfixes
A few bugfixes
2017-12-24, 11:13
More than half of feeds won't load to me. Now, I realize it's not addon's fault, as fcc is just an aggregator for other sites with different stream formats. Yet, I suppose if the answer exists, people who know it might likely be found here. What other addons and services I could install to make more feeds playable? Thanks.
If it helps, here's Kodi's log: https://www.dropbox.com/s/b2zb9136ihfwfcn/kodi.log?dl=0
2017-12-28, 03:46
(2017-12-24, 11:13)KillerBeer Wrote: [ -> ]More than half of feeds won't load to me. Now, I realize it's not addon's fault, as fcc is just an aggregator for other sites with different stream formats. Yet, I suppose if the answer exists, people who know it might likely be found here. What other addons and services I could install to make more feeds playable? Thanks.Correct it depends on the originating site. The solution is to update this plugin. Thanks for the log. I will have a look over the next few weeks unless someone beats me to it.
2018-01-02, 15:38
(2017-12-28, 03:46)dquaid Wrote: [ -> ]Are you running the latest fantasti.cc version ? Could you post your fantasti.cc version?(2017-12-24, 11:13)KillerBeer Wrote: [ -> ]More than half of feeds won't load to me. Now, I realize it's not addon's fault, as fcc is just an aggregator for other sites with different stream formats. Yet, I suppose if the answer exists, people who know it might likely be found here. What other addons and services I could install to make more feeds playable? Thanks.Correct it depends on the originating site. The solution is to update this plugin. Thanks for the log. I will have a look over the next few weeks unless someone beats me to it.
2018-01-06, 19:14
The version this log was made with was 2.3.37. I updated to 39 since then, though. There are still refused feeds, but I wouldn't say for sure whether there are less of them now or just the same.
