2012-02-12, 15:00
2012-02-12, 19:02
Edit: Nevermind. A re-boot fixed issues.
2012-02-12, 20:28
worked for me on for fantasti but not xvideos, pornhub, xhamster and redtube. These show under videodevil and they don't work any ideas?
thanks
thanks
2012-02-12, 21:42
johnnyb12 Wrote:I copied this file to my videodevil folder and now getting script error on apple tv. Is this where it goes?
opps, sorry for the double post
gonefishing1975 Wrote:worked for me on for fantasti but not xvideos, pornhub, xhamster and redtube. These show under videodevil and they don't work any ideas?
thanks
No, this fix is for fantasti.cc only, videodevil is a different addon
2012-02-12, 22:26
Is xvideos, pornhub, xhamster and redtube part of fantasti?
thanks
thanks
2012-02-13, 00:38
Updated the plugin. Again sorry about the delay.
2012-02-13, 01:59
Great work. Thanks.
2012-02-13, 02:03
can someone provide the link to the update from today please
Thanks all
Thanks all
2012-02-13, 04:38
If you already have the add on installed, it should update automatically when you load XMBC, and then go to video add ons. At least that's what mine did. Good job. Thank you!
2012-02-13, 20:58
dallasnights Wrote:can someone provide the link to the update from today please
Thanks all
First post of this thread.
2012-09-23, 00:40
Fantasti.cc addon is broken after the latest update (2.3.0) it was working until last night. this morning xbmc updated it.. now it gives scrip errors on load.
Any solution?
Any solution?
2012-09-23, 02:36
Having same problem, worked last night but won't work today. Fantasti.cc in xbmc on atv gets script failed.
2012-09-23, 12:30
Hi
It would appear the problem relates to including a lib that's not compatible or from a different python version maybe
if you edit line 11 of
"/Users/frontrow/Library/Application Support/XBMC/addons/plugin.video.fantasticc/default.py"
and comment out the lib include then you regain *some* functionality
fixing it properly is beyond my ken though...
11:12:01 T:62912512 NOTICE: -->Python Interpreter Initialized<--
11:12:05 T:62248960 NOTICE: -->Python Interpreter Initialized<--
11:12:12 T:64366080 NOTICE: -->Python Interpreter Initialized<--
11:12:13 T:64366080 ERROR: Error Type: <type 'exceptions.ImportError'>
11:12:13 T:64366080 ERROR: Error Contents: Bad magic number in /Users/frontrow/Library/Application Support/XBMC/addons/plugin.video.fantasticc/sesame.pyc
11:12:13 T:64366080 ERROR: Traceback (most recent call last):
File "/Users/frontrow/Library/Application Support/XBMC/addons/plugin.video.fantasticc/default.py", line 11, in <module>
import sesame
ImportError: Bad magic number in /Users/frontrow/Library/Application Support/XBMC/addons/plugin.video.fantasticc/sesame.pyc
11:12:13 T:2684407808 ERROR: GetDirectory - Error getting plugin://plugin.video.fantasticc
11:12:13 T:2684407808 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.fantasticc) failed
#!/usr/bin/python
#Code Heavily modified from Demo by TV DASH - by You 2008.
# Written by Ksosez with help from anarchintosh
# Released under GPL(v2)
import urllib, urllib2, htmllib
import re, string
import os
import sys
#import sesame
import xbmcplugin, xbmcaddon, xbmcgui, xbmc
2012-09-24, 14:18
python version problem
workaround uploaded
workaround uploaded
2012-09-24, 17:49
(2012-09-24, 14:18)dquaid Wrote: [ -> ]python version problem
workaround uploaded
where can i get this file?
