Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
(2014-04-04, 01:31)hindibuff Wrote: [ -> ] (2014-04-03, 23:19)dquaid Wrote: [ -> ] (2014-04-03, 22:33)hindibuff Wrote: [ -> ]Where can I find the repo for it? The google adult-xbmc repo listed on the first page seems empty.
See http://forum.xbmc.org/showthread.php?tid...pid1546394
Thanks. just tried 1.05 and still empty repo. Forced refresh doesn't result in anthing either.
Same here... Uninstalled and installed this. Nothing appears even after for refresh and check for updates. :-(
Thanks, yeah installing the raw addon seems to have worked. I'll keep trying to update the repo anyways.
Is there a way to download videos from fantastic.cc with this app using jdownloader?
yes its empty links and not working
From what I can see, the problem is fantasti no longer put the xvideos/xhamster etc (SUPPORTEDSITES) info into the url info
if you change the below section in default.py then that gets the list back up by looking at the info in the thumbnail location (which appears to have this info)
def addSupportedLinks(gurl, name, thumbnail):
for each in SUPPORTEDSITES:
if each in thumbnail:
realurl = 'http://fantasti.cc%s' % gurl
mode = 4
addLink(name, realurl, mode, thumbnail)
break
else:
pass
However GET_LINK function is still broken as it's doing similar in respect to switching on the wrong info (url) and so not finding a match. My python isn't good enough to see how to fix this unfortunately but hopefully it gives someone else enough info to fix the problem.
**** EDIT ****
Have got something going, it ain't pretty, but this replaces the current default.py :
http://pastebin.com/9NqisHgQ
thx so much for trying and for your help however I'm confused and don't know where in default.py i can find and change this code
thx i diid open it with text edit but could not catlike and how rot do it thx
I just saved the file, then put it in the directory, renamed the old default py defaultold, and then took this new file and renamed default.py and it works great
Thanks for the fix
can some one tell me exactly where this file goes on xbmc for windows as I am having trouble finding where it goes
I will have a look but it could take long
Fixed, but some sites don't work like x hamster and there was an issue when I clicked "Next" for one of the collections but some things are working
(2015-03-16, 23:40)dquaid Wrote: [ -> ]Fixed, but some sites don't work like x hamster and there was an issue when I clicked "Next" for one of the collections but some things are working
Most of the collections are working again, that's a good start. Thank you very much.
In my opinion fantasti.cc does have the biggest porn collection available for a kody addon, the movie quality isn't always good, but the number of videos is just huge.
It does have the best search engine available for porn movies.
