nessus
Skilled Skinner
2012-05-17, 19:09
(This post was last modified: 2012-05-28, 03:42 by nessus.)
UPDATE: Xperience More v1.3.1
• Fixed some typo font sizes (42px instead of 24px) in system info screen.
• Added missing VideoInfo fanart in InfoPanel view for tvshows and seasons.
The update will be in the official repo in a couple of days. GitHub is updated now.
Cheers
Nessus
Is there any way the fanart tri panel being added to tv shows?
nessus
Skilled Skinner
Sure, but it requires some coding. If you want it i can add it to the next update.
Is there anyone else that wants this ?
Cheers
Nessus
echo
Senior Member
Hello... just to report a couple of bugs:
1) When you start playing a movie, and pause within the first minute or so, the "gold progress bar" is displayed half full. After the first minute-thirty-seconds, the progress bar displays what it's supposed to....
2) In the full wall view for movies & tvshows, if you select the context menu for an item on the outskirts (ie located in row(0), row(2), column(0) or column(7)), the poster jumps off screen slightly ..... it would be cleaner if the poster just stayed in place (like it happens with the middle items).
That would be great the view is fantastic for movies so would
Look great on tv shows thanks in advance
I love the skin but I am having a problem with Trailers
I am running Xperience More v1.3.1 and I want to use the "Info Panel" display for Trailers.
The problem is that the movie info is not displaying for most of the videos.
The center section is blank.
If I hit the info button to go to the screen where you can Get thumbs, fanart and artwork I can see all of the info.
I believe it was working correctly at first but I changed my setting from "streaming" to "download and save".
I think that's when I lost the info.
Now it doesn't matter which setting I try I can't get the info back for most of the videos.
Fanart Tri Panel and Tri Panel views in TV Shows will be added in the next update.
Great thanks perfect skin great work !!!!
nessus
Skilled Skinner
UPDATE: Xperience More v1.3.2
• Fixed bug of missing info in several views after trailers settings changed.
• Fixed progress bar bug in VideoOSD.
• Fixed visible conditions for movies collections in several views.
• Added Tri-Panel view in TVShows.
• Added Fanart-Tri-Panel view in TVShows and Episodes.
• Recoded/replaced all the animations and the visible condtions in FullWall view to avoid the context menu ugly flip.
GitHub is updated.
This update will not pushed in the official repo yet.
Cheers
Nessus
Thanks for that
One thing when in view could the left window show season poster art ?
Just looks a little strange with nothing there.
Again big thanks !!
