Vaikin
Posting Freak
If you want to stick with Frodo and have artwork, you'd have to switch away from MQ4(for now) and use a Frodo ready skin. Like Martijn said, Nox works great with Frodo. It's not 100% completed, but it definitely works.
If you want to keep MQ4, then you'd have to switch back to Eden.
2012-12-10, 23:31
(This post was last modified: 2012-12-10, 23:31 by BB944.)
well in that case .... i am going to do a bit of a hybrid
Uninstall Frodo, install Eden, install MQ4 and Nox, and stay on Eden until things are more comfortable with Frodo.
Also another slightly unrelated question... I have like ... oh i dont know..... close to 8K songs. And I used to use MM with a AMG tagger, but like IMDB they changed their site and now it is broken. And I noted that this program (XBMC) has the ability to download album art and what not. Will it tag my music with this information or is it just in the DB for XBMC... I know this has little to do with your script ... but i just thought I would ask
Just throwing it out there...
I use Frodo (used the monthlies, now using the Betas, decided to stay away from nightlies this time around) and I also use MQ4. It might be due to the fact that I have had it setup for some time, but MQ4 works perfectly fine for me (When you install it, it goes through the setup and you need to make sure you selected "Pre-Frodo", not "Eden").
As long as there is a logo.png, clearart.png, folder.jpg/poster.jpg, backdrop.jpg and the extrafanart and extrathumbs folders in the directory you have the movie in, everything displays fine.
I've just run Artwork Downloader (had to disable all banners as mentioned in above posts due to the "n/a" error in the logfile) and downloaded an additional 625 items, including clearart, logos and cdart...
I know this doesn't fix your issue, but it should go some way to confirming it should be working...
bobrap
Posting Freak
Strange problem/question...every time I do a scan the script fails when it gets to "The Walking Dead". Is there something I'm missing? Thanks
YOYIZDERZOMENEMOHOZEZAZEZDENDERIZHOZEZ
2012-12-12, 01:32
(This post was last modified: 2012-12-12, 01:32 by Tomkun.)
I was having a problem with my TV shows appearing and wanted to share the fix; although I don't know if this problem is caused by XBMC, Artwork Downloader or even a third-party program.
I had a strange situation where two or three TV shows would scrape artwork just fine, but the rest would return an error saying 'id not found' or something similar. I realised that there must have been something on my end preventing it working, so I checked all the nfo files of the TV Shows and noticed that the ones that did scrape fine had the <id> tag. The ones that didn't had a <tvdbid> tag. These nfo files were created by a program called 'TVrename', which I have been using for years.
The quickest fix I found was to delete the nfo files, let another program such as SickBeard recreate them and then finally reimport into XBMC. Then your shows should scrape just fine.
Now is this due to
1) XBMC not finding the ID and importing it to the database or
2) Artwork Downloader not finding the <tvdbid> tag?
tldr;
If your TV shows aren't scraping properly make sure they have a valid <id> tag inside the nfo file.
Hi Martijn,
i can't get showing any downloaded logo.
XBMC RC1 and latest Version of Artwork Downloader (12.0.11)
Example TV Show Level
Here my image control:
<texture>$INFO[ListItem.FilenameAndPath,,/logo.png]</texture>
Starting Artworkdownloader from Info Screen:
<onclick condition="Container.Content(tvshows)">XBMC.RunScript(script.artwork.downloader, mode=gui, mediatype=tvshow, dbid=$INFO[ListItem.DBID])</onclick>
In AD Settings "Local Files disabled"
If i use:
<texture>$INFO[ListItem.path],,logo.png</texture>
Only local files (logo.png) are visible.
Someone an idea ? Thanx ...
You did know that you can use ListItem.Art(clearlogo) now?
* Martijn reminds himself to update the wiki
