Something else i've noticed, checking the ID's ...
Undefined IDs:
142
but ID 142 is for DialogFullScreenInfo
<window type="dialog" id="142">
Searched all xml's in the skin folder, no double entries found for id="142". Is this a known behaviour ? Or i'm just missunderstanding something ?
thanx
Kib
Team-Kodi Member
2013-03-04, 20:12
(This post was last modified: 2013-03-04, 20:18 by Kib.)
Quick question:
When there is a Double XML Tag and you let the tool autocorrect that - it will remove the last one.
Isn't that the one that the XBMC engine actually uses when there are two ?
I have many cases where they aren't identical and just wanted to make sure.
Kib
Team-Kodi Member
2013-03-04, 21:45
(This post was last modified: 2013-03-04, 21:45 by Kib.)
That is exactly what I meant.
Thanks Hitcher!
Hi Phil,
When converting 720 to 1080, if I use <bordersize>top,left,right,bottom</bordersize> format on an image, I get the log error 'Input string was not in a correct format'. However If I use a single number, so <bordersize>number</bordersize>, it converts ok.
Any ideas? Bug or me being stupid!?
`Black
Team-Kodi Member
2013-05-07, 12:10
(This post was last modified: 2013-05-07, 12:11 by `Black.)
It's invalid. Bordersize takes a single number only or the wiki is missing information.
Edit: Scratch that... phil might have forgotten to check that.
when i try to convert a skin, i cant convert animations, it says tween is an unexpected token. can anyone advise me how to convert animations manually if this cant, thank-you
Hitcher
Team-Kodi Member
I can't run this on Windows 8, any ideas?
Hi Phil,
Any chance we can get the tool fully updated for Gotham? BigNoid's changes work great but it still flags stuff like the colordiffuse attribute for textures.
BigNoid
Team-Kodi Member
The original developer of this tool doesnt maintain it anymore. The changes I made are pure for my own use, if this tool is to be developed for gotham and beyond someone (else) has to step up.
