2013-07-23, 17:41
Hi Guys,
Thanks for great work you are doing!
I'm trying to compile the libstagefright release from the sources.
I'm using the Ubuntu 12.04 x32 virtual machine.
I'm getting the error:
Here's the compile instructions I used to build the libstagefright XBMC:
https://docs.google.com/document/d/1fDd3...sp=sharing
Could you please advice on this issue?
does anyone has a working compile instruction?
Thank you!
make -C arm-linux-androideabi-android-14
make[3]: Entering directory `/home/developer/libstagefright/xbmc-android/tools/depends/target/pcre/arm-linux-androideabi-android-14'
make[3]: *** No targets specified and no makefile found. Stop.
make[3]: Leaving directory `/home/developer/libstagefright/xbmc-android/tools/depends/target/pcre/arm-linux-androideabi-android-14'
make[2]: *** [arm-linux-androideabi-android-14/.libs/libpcre.a] Error 2
make[2]: Leaving directory `/home/developer/libstagefright/xbmc-android/tools/depends/target/pcre'
make[1]: *** [pcre] Error 2
make[1]: Leaving directory `/home/developer/libstagefright/xbmc-android/tools/depends/target'
make: *** [target/.installed-arm-linux-androideabi-android-14] Error 2
developer@ubuntu:~/libstagefright/xbmc-android/tools/depends$
Thank you!
