Diggs
Senior Member
2013-03-05, 23:18
(This post was last modified: 2013-03-11, 18:40 by Diggs.)
Hello all, having a problem that I know others posted about here, but I can't find the thread.
Problem:
I want to leave my HTPC and XBMC running 24/7 and power down my TV everyday. After powering down, leaving the TV off overnight and normally while at work the following day, I power on the TV, XBMC is still running but has been shrunk down to small box of about 800x600. It is not a window, there is no windows border. It functions but I can't get it to return to full screen without shutting XBMC down and restarting. I assume this has something to do with the loss of connection between the HTPC and it's monitor. It is an HDMI connection between the two. I have left the TV on overnight (waking up on the couch the next morning) to find the screen saver running on XBMC and it's still full screen. So again, I am assuming it has something to do with the monitor/TV being powered down and XBMC or the AMD drivers are doing something to try and compensate for the unknown resolution and lack of connection.
I want to say the thread I kind of followed a year ago had a script that would prevent this from happening. Can anyone point me to that thread or give me a method to prevent this from happening. I just started using WatchDog and it was awesome to return home yesterday and all the new files I had dropped onto the server showed up in the library without an update. But It was a bit of a downer to have to restart XBMC to use it full screen.
Thanks!!
Diggs
Senior Member
I just thought of a few other details that may help or be important.
When i turn the TV on and xbmc is 1/4 screen, the windows desktop is behind it running full screen 1920x1080. So only xbmc is affected, windows seems to be ok with the TV being off for several hours.
My HTPC is not in sleep mode or hibernate. I have disabled both of those, and no other power saving features are enabled as best I can remember.
PatK
Team-Kodi Member
Just wondering what size XBMC is when you hit the 'slash key' for windowed mode..? I suspect that some service or something PC is taking XBMC out of full screen mode and into windowed mode which remembers your last windowed size... To check this, hit the slash key and see if it's a quarter size. If this proves out,
<advancedsettings>
<fullscreen>true</fullscreen>
</advancedsettings>
Will give you the size... then it's a matter of tracking down what is causing this. I'd hate to think this might anything to do with HDCP handshaking.
Diggs
Senior Member
Thanks Pat, I will check it when I get home and report back. However, I seem to remember a thread about it being a handshaking issue. I have been searching HDMI, I will try a new search for HDCP and see if I can find that thread. It was a hot topic around the time Darhma went to Eden.
Thanks again.
Diggs
Senior Member
Ok, the \ does in fact still toggle xbmc from windowed to full screen, but the windowed mode it is in AFTER hitting the \ is not the same as when I first power on the TV. And tonight the behavior was different.
Here is what happened tonight. Power on the TV, Windows 8 desktop opens with XBMC over to the top left corner of the screen. However, tonight the size of the XBMC screen was very different that it has been in the past. I am guessing it was 240 pixels wide by 8-900 pixels tall. I have never seen it at that size before. Hitting the \ key centered a true Windowed XBMC in the center of the desktop with the typical windows boarder with minimize, maximize and close buttons on the top left. \ again goes to true full screen no windows boarder (what I want). So I have 3 distinctly different states that XBMC is in during the first 3 presses of \.
1. Normally a box about 800x600 in size but tonight much thinner and a bit taller probably 240x850
2. A typical Windows application window. Go to settings to check size and I can't read the resolution setting it is too small.
3. Typical full screen no boarder.
On the 4th press I toggle between 2 and 3 above, it never returns to the bizarre boarderless top left corner box.
Going to drop those settings into advancedsettings and see what happens. Won't be able to test till tomorrow evening and have no idea how long the TV must be off before this happens again. I did find a thread at work about this, only 2 posts long, same exact issue, no resolution and both posts came from people using AMD onboard video. I know one of them if not both had APU's like my A8. I will try to find that and post the link.
Again thanks for the help and it maybe an AMD thing.
Diggs
Senior Member
Gazzyb,
Thanks for the input and that is kind of what I thought. I think AMD when unable to detect a monitor sets itself to a safe resolution as you point out of 800x600. The video output settings are already at full screen and 1920*1080, but I don't know how to get the AMD drivers to stop it's little safety feature. I will search some more. Seems there is a thread about this at AVS but the utility to create a new monitor.inf (their proposed solution) doesn't play nicely with windows 8.
I did drop the line <fullscreen>true</fullscreen> in the adv.xml file as suggested above. For giggles i will search LG for a windows inf file, but I highly doubt I will find one.
I had this happen before I started booting into a shell. What I discovered was XBMC would still work and when I played a movie or TV show it refreshed and fixed itself.
XBMC specs: MINIX U9-H LibreELEC 4K all day
Home Theater - Samsung 65KS8000 - Denon 3200- Ascend Acoustics speakers - Maelstrom 18in sealed sub 7cu ft - Behringer EP2500
UNraid Server – Pentium G3258 – MSI - H81M-P33 – Antec HCG-400M PS - 8Gb RAM
2013-03-08, 08:42
(This post was last modified: 2013-03-08, 08:48 by nick w.)
Did you try the blocking the pin on the HDMI cable
I too have the same issue
I did try to use a script to force the resolution back but it didn't work
It isn't an xbmc issue as I had the same problem when using plex.
I'm going to try the pin blocking when I have some time over the weekend.
N
The 19th pin block method looks like the one for me this weekend.
