I've had to reset my library a few times. Is there a way to quickly mark whole seasons of shows as watched or do I have to go episode by episode?
Thanks,
JOe K.
Frodo Win 8 Pro x64
Fractal Design Node 605 (looks amazing)
i5 3570K, Asus P8Z77V LK
2x80GB Intel 320 SSD, 4TB NAS
GTX 670x2 SLI, 16GB GSkill Ares
Onkyo RC360 with Paradigm piece-by-piece 5.1 build
Nyxboard and AHK full controlled via XBox Controller
pkscout
Team-Kodi Member
You should be able to do the entire show. When you're in the list of shows:
1- highlight the show in question
2- bring up the context menu (probably 'c' on your keyboard)
3- select MARK AS WATCHED from the menu.
un1versal
Out of Memory (1939–2016)
Select the TV show and bring up context menu and select mark watched. You can only mark per tv show/season/episode.
XBMC will seem frozen for a while as it processes and marks all the episodes under that showname, the more it has the longer it will take, 1 second per episode give or take.
uNi
2013-03-20, 09:50
(This post was last modified: 2013-03-20, 09:50 by ezechiel1917.)
You can press 'w' on your keyboard directly to mark selected item as watched/unwatched or map 'ToggleWatched' to your remote button.
