2013-10-02, 18:03
2013-10-02, 20:28
Ya, got me too. With every previous upgrade I've simply copied everything overwriting the old directory and the settings and database stayed intact.
With this version I am still seeing an HTTP error pop up when scanning new items, but at least it's working, thanks Dan!
2013-10-02, 23:01
(2013-10-02, 20:28)voip-ninja Wrote: With this version I am still seeing an HTTP error pop up when scanning new items, but at least it's working, thanks Dan!
You can ignore this HTTP errors.
2013-10-03, 08:29
Thanks for the update. I am also getting lots of error messages though ("an error occured") and resulting crashes. I enabled trailers, but left all other options "as is". Any thougts!
Title: Error: R:\Folder\Movie-fanart.jpg
Message: Parameter is not valid.
StackTrace: at System.Drawing.Bitmap..ctor(Stream stream)
at EmberAPI.Images.FromFile(String sPath)
Date/Time: 10/3/2013 2:33:02 PM
2013-10-04, 01:39
I am getting error Object reference not set to an instance of an object every time i scrap a movie.
2013-10-04, 05:11
And more error messages when scraping multiple files (it is working for single-scrape):
Title: Error
Message: The operation has timed out.
StackTrace: at System.Net.ConnectStream.Read(Byte[] buffer, Int32 offset, Int32 size)
at EmberAPI.HTTP.DownloadImage()
Date/Time: 10/4/2013 11:01:26 AM
Title: Error
StackTrace: at System.Net.HttpWebRequest.GetResponse()
at EmberAPI.HTTP.DownloadData(String URL)
Date/Time: 10/4/2013 11:01:59 AM
Title: Error
Message: Index and length must refer to a location within the string.
Parameter name: length
StackTrace: at System.String.InternalSubStringWithChecks(Int32 startIndex, Int32 length, Boolean fAlwaysCopy)
at System.String.Substring(Int32 startIndex, Int32 length)
at EmberScraperModule.IMDB.Scraper.SearchMovie(String sMovie)
Date/Time: 10/4/2013 11:02:05 AM
Title: Error
Message: Object reference not set to an instance of an object.
StackTrace: at EmberScraperModule.IMDB.Scraper.GetSearchMovieInfo(String sMovieName, DBMovie& dbMovie, ScrapeType iType, ScrapeOptions Options)
Title: Error
at System.IO.Compression.DeflateStream.Read(Byte[] array, Int32 offset, Int32 count)
at System.IO.Compression.GZipStream.Read(Byte[] array, Int32 offset, Int32 count)
at System.IO.StreamReader.ReadBuffer()
at System.IO.StreamReader.ReadToEnd()
Date/Time: 10/4/2013 11:07:55 AM
Title: Error
Title: Error
Title: Error
Title: Error
Title: Error
2013-10-04, 11:57
Please upload advancedsettings.xml and settings.xml to a file hoster or http://pastebin.com/
2013-10-04, 16:07
(2013-10-04, 13:03)steve1977 Wrote: Thanks for looking into it. Here we go:
https://www.paste.to/ceZ4we6v
I need also the advancedsettings.xml
2013-10-04, 17:30
One more observation in version 1.3.15. It somewhat works to automatically scrape up to two new movies. Error messages are starting from the 3rd movie onwards.
2013-10-12, 19:53
