2013-09-08, 14:36
(This post was last modified: 2013-09-08, 17:52 by Trickname.)
Live tv is working here with latest frodo build.
Did you make a clean setup Jönke ?
Jönke
Posting Freak
Nope, just a update over smb.
Are you using tvheadend ?
2013-09-08, 17:52
(This post was last modified: 2013-09-08, 18:32 by Trickname.)
make sure that you propper update kernel.
(double check that if you using using boot=/dev/sda1 in cmd.txt) or similar.
my setup:
rpi 512, rbej build usb install, Argus tv server (winpc), FloppyDTV card, wired lan
and live tv is working since 07.09 Frodo but channel switch is slow
Jönke
Posting Freak
It had nothing to do with a update issue, just made a clean install of latest rbej Frodo and it`s the same issue, no live tv.
rpi 256, sdcard, tvheadend client, wired lan
Dear Popcornmix et al,
Please can we add to the config.txt file for the distribtion 3.1.8 and going forward, and 3.0.7 if it comes out, the following option with a comment about it:
#Stops HDMI res-sync issues between raspberry and external AMPs (needed to achive near gapless audio play back in some situations)
force_hdmi_open=1
I have tried it with my Raspberry model B, and Yamah AMP connected via HDMI and albums now play as if listening to the original CD from my CD player!
I personnall would like it on by default.... lol but then I would, but it should be in there as an option to enable. I could not find this documented
on the RPI site/forum, it has taken me since last September to get this going, as I did not assoicate the issue with montiors or popping sounds lol.
Again I would like to thank Popcronmix for suggesting this in another thread I posted in. I am sooo so happy with openelec 3.1.6 now.
JB
(if you want me to test a build with this in let me know and where to grab it fromand I will)
