2014-11-12, 00:53
New OpenELEC Helix build: #1111
(Supercedes previous build)
Based on tip of OpenELEC master (c844e210, changelog) and tip of XBMC master (bd7da380, changelog) with the following modifications:
# uname -a
Linux rpi512 3.17.2 #1 PREEMPT Tue Nov 11 22:25:12 GMT 2014 armv6l GNU/Linux
# vcgencmd version
Nov 7 2014 17:01:00
Copyright (c) 2012 Broadcom
version 3bd41a132583ec90e4a0410a4aa631d1e4e2d8ea (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20141111222404-r19619-gc844e21 [Build #1111]
- Includes newclock4 patches
- Excludes the OpenELEC fernetmenta patches due to conflicts with newclock4
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-3.17.y
- Excludes the OpenELEC xbmc-001-newclock4 patch in favour of sourcing these and possibly more recent patches directly from newclock4 branch
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Adapted service.openelec.settings to take advantage of PR:5217 [patch details]
- Includes latest libnfs master (4a58e614)
- Includes latest libcec master (260df18a)
- Includes latest xbmc-pvr-addons master (bd3f2de9)
- Includes latest xbmc-addon-xvdr master (328fa653)
- Includes CONFIG_COREDUMP=y to allow creation of coredumps (see here)
- Includes additional ffmpeg codecs/muxers enabled for testing/benchmarking purposes (see patch)
- Includes commits from libcec-2.2.0 (popcornmix)
- Includes PR:373: Release v1.9.25 (kodi-pvr-addons)
- Includes PR:374: [pvr.hts] Backported GetPlayingTime from pvr.tvh. (kodi-pvr-addons)
- Includes PR:5573: webserver: improved caching control (see discussion)
- Includes PR:5625: Fix library clean/scan after #5324 when started from a remote.
- Includes PR:5629: [PVR] Timeshifting: Fixed EpgInfoTag::[IsActive|WasActive|InTheFuture]
- Includes PR:5663: Add RunScript backwards compatibility
- Includes PR:5688: fix 'action' type addon settings not executed if id attribute is missing
- Reverted e502b099: Reason: may be responsible for ISO playback issues?
- "add canseek and drop unused rtmp options" - should fix hangs while watching live streams and accidentally seeking (see discussion, thanks wsnipex & popcornmix)
- Reduce threshold for resetting demuxer when audio/video out of sync from 2 seconds to 1 second
- OpenELEC:
- projects/imx6/linux: enable RTC on TBS Matrix system (PR:3602, 1 commit, 2 files changed)
- [SDL2] add patch for missing axes (PR:3593, 1 commit, 1 file changed)
- tbs-linux-drivers: update to v141019 (PR:3586, 1 commit, 1 file changed)
- update NVIDIA drivers to 340.58v (PR:3608, 1 commit, 1 file changed)
- projects/imx6/patches/libcec: remove project based libcec patches (fcbbd034)
- projects/imx6/patches/linux: update project based CEC driver patches (4af9f407)
- libcec: update to libcec-2.2.0 for all plattforms, add updated patch to add support for iMX6 systems (ba41891f)
- projects/imx6/patches/kodi: remove libcec-2.1 support patch (9a6b715f)
- OpenELEC-settings: update to OpenELEC-settings-0.5.3 (b436b09f)
- xorg-server: update to xorg-server-1.16.2 (9f20e71f)
- lirc: specify localstatedir so /run/lirc is used for socket and pid files (ebd56774)
- irserver: change lirc's runtime dir to /run/lirc (26d87ad0)
- kodi: Add av.xml setting to set minimal sample rate (c844e210)
- XBMC:
- binary addons: fix dependency handling for dependencies (PR:5680, 1 commit, 1 file changed)
- AE: Some more coverity fixes this time for ActiveAE (PR:5668, 3 commits, 17 files changed)
- [infomanager] only update a/v info if something has changed and only by ... (PR:5676, 1 commit, 15 files changed)
- videorefclock: fix clock speed for D3D after refactoring (PR:5679, 1 commit, 6 files changed)
- AE: Some fixes for the Cubox hardware (PR:5682, 2 commits, 2 files changed)
- renderer: use 3 render buffers for sw decoding, restores bahavior after ... (PR:5689, 1 commit, 3 files changed)
- dvdplayer: improved dropping control (PR:4639, 3 commits, 7 files changed)
- [lang] update of internal addon language files (8e465155)
- [lang] update of core language files (9425fba4)
- [lang] update of skin.confluence language files (317683bc)
- [lang] update of internal addon language files (c3dbcbbc)
- [lang] update of core language files (98aad9ef)
- [lang] update of skin.confluence language files (194c2cb6)
- kodi-pvr-addons:
- newclock4:
- New commits in this build:
- Commits no longer in build:
- videoplayer: adapt lateness detection and dropping to buffering (83a43f13)
- video player: present correct pts to user for a/v sync (after buffering in renderer) (cd8844cc)
- videoplayer: update frametime, it might change due to fps detection (aa2d1a6b)
- only update a/v info if something has changed and only by main thread (08519b63)
