2017-05-14, 18:31
Thanks Sean and your right.
(2017-05-14, 17:52)spoyser Wrote: 1) Can you let me know the name of an addon that doesn't work. Just to confirm that the way this is supposed to work is that a Super Folder, if it hasn't got fanart set (or thumbnail) it will display the fanart of the first item in that folder.No, I can't As mentioned I had added manually all missing fanarts, but I don't remember in retrospect which ones have been affected or not.
(2017-05-14, 13:15)spoyser Wrote:(2017-05-10, 04:02)AL8782 Wrote: Not sure if it is me, but global menu stopped showing after update. I had to go back to previous version for global menu to work for me again
(2017-05-10, 06:47)ed_davidson Wrote:(2017-05-10, 04:02)AL8782 Wrote: Not sure if it is me, but global menu stopped showing after update. I had to go back to previous version for global menu to work for me again
Correct, I'm having the same or similar issue. If I was playing a Youtube video in full screen then I could bring up the OSD and click the X. That would launch the LaunchSFMenu.py and bring up the option to download the Youtube video.
Since the update, I just takes me to Now playing video.
Would love this to work again.
Thanks Sean, Great to have you back
Can you try this:
https://www.dropbox.com/s/0m0ukx6sre8vhi...1.zip?dl=0
Don't worry I released it as version 1.0.58
(2017-05-30, 12:58)k0d1_ Wrote: Hi SP
I am currently running v.1.0.48 not sure why it has not updated automatically if newer versions are available.
It would be nice if a backup/export feature was implemented to the plugin, currently I am having manually copy folders and xml files across to my other devices if I want to replicate my favorites.
Other than that, SuperFavourites is one of the must have plugins in my list, thank you for developing it.
(2017-06-04, 04:09)StreamSlayer Wrote: No one has so much as a hint as to why it's not working for me?
(2017-06-06, 23:54)wsh2watch Wrote: Greetings "Super" (<-understatement) Sean.. {smile}
Your time, energies, and scholarship invested in 'Super Favourites' is without parallel. Thank YOU so very, very much!
I recently upgraded from Jarvis to Krypton and, while I am NOT certain of the cause, I think I am having a problem with Super Favourites. Here is what happens.
When I am on a SF list item and click context menu a Menu pops up on the left hand side of the screen. The menu reads:
MENU
Edit Super Favourite
Copy Super Favourite
Add to Kodi favourites
Explore Kodi favaourites
Super Favourite settings
When I click on "Edit Super Favourite" another sub-menu appears. Unfortunately, only the lower right corner of this sub-menu appears in the upper left hand corner of the screen. Assuming that an upper left corner (x,y) position attribute of the screen is {0,0}., it seems that the sub-menu's upper left position point is (negative, negative) causing the sub-menu to crop the upper left area fo the sub-menu.
Without the left portion of the sub-menu visible you cannot read the sub-menu option (eg. 'Delete', 'Rename', etc.) descriptions. All you can see is the end of a highlighted line. Highlighted line navigation still works and if you click on the highlighted line the sub-menu option will work (even though you cannot read the description).
Edit: This also affects the "Resume From" / "Start From Beginning" dialog box when replaying a video.
How can I get the sub-menu to properly position itself so I can read it?
Thanx bunches!
Environment:
Android 5.1.1
Kodi 17.3
Super Favourites 1.5.9
Titan 3.7.56 skin
NB: Everything works fine on my identical Windows 8.1 install.
