(2014-11-10, 15:03)phil65 Wrote: no, in general you only access your xbmc userdata folder, not your source path.
Sure I get that, it's just if I'm looking thru my video library (userdata folder) it's usually because I'm looking for something to play (My source path), so having my NAS spool up while I'm looking is a positive, not a negative. But, that's my use case and I appreciate that it may not be everyone's use case (or anyone's use case for that matter). Was just a suggestion, move along, nothing to see here ;-)
Quote:yesnodialog and selectdialog are already implemented. Example:
RunScript(script.toolbox,info=yesnodialog,header=Shutdown,text=$LOCALIZE[31149],yesaction=Dialog.Close(all,true)|Quit())
Cool, will have to go poke thru your script and see what else is lurking there (hopefully my brain will not explode from reading python)
Quote:The blur stuff should be used in a senseful way, please don´t clutter your skins with it (depending on source image and blur radius it can take some seconds)
Not sure yet how to deal with the android situation. Will see.
No such thing as a free lunch, will definitely use this one sparingly. My vertical home menu used to use skin supplied blurred icons to denote depth (icons were coming from the distance and into view), but could not do the same with custom user supplied icons, so I dropped this idea. I instead used a colour diffuse (darker was further away) and made the distant icons smaller. Would be nice to be able to re-add this original idea and still allow for custom icons.
Thanks for working on these scripts, I know my skin has benefited from a number of them.
Wyrm (xTV-SAF)
