2015-09-18, 18:56
(This post was last modified: 2015-09-18, 19:02 by meridius.)
Hi Richard
looking good but the audio menu you need to switch the colours around the" audio streams" text box is the light colour and the icon with the ear is the dark colour with the outline around it matching the ear icon box colour
also I need to send you the subtitle icon to forgot about that for the subtitle menu
could you send me a high res image to see if the icons buttons at the bottom are the right location and size, also can you add an option for 24h or 12h settings
I have changed the screen shots.
ok audio stream would be better as it fits inside the dimensions of the button I designed and placing a "s" goes outside that but audio stream sounds good to
It's a remote control for Kodi, just are following Kodi's terminology...
2015-09-19, 10:12
(This post was last modified: 2015-09-19, 10:15 by meridius.)
you still could call it Audio Stream since kodi calls it Audio Stream and not Audio Streams and that would fit if you are following Kodi's terminology
its up to you Richard, but don't change the font size
also does the menu slide up from behind the bottom buttons
thanks
2015-09-19, 10:27
(This post was last modified: 2015-09-19, 10:27 by rschiks.)
No, no animation. The only thing that will be animated is the info bar (up and down) and the functions menu, it's already programmed to be animated and I just have to call it.
could you please make a sliding up and down window when selecting it I think it will make it look more polished and that was my thoughts when designing that window that's the reason I did it that way.
