  • 71
  • 72
  • 73(current)
  • 74
  • 75
  • 270
Release skin helper service
(2015-12-04, 01:05)BobCratchett Wrote: The old Google image search api - long since deprecated - has now been discontinued, so all Google image searches by the script are failing.
OMG ... Noooooo !
[Skin] KOver - V1.1.0 Stable (Repo version)
[WIP] ReKOver - Skinning tool project
If I've been helpful or you like my work, hit "THANK USER" button ;) ...
(2015-12-04, 00:29)marcelveldt Wrote: Like mentioned before by Rjsachse you can put any info you like in the pvrdetails.xml file and it will result in a window property.
I will look into scraping the ratings and mpaa from TMDB/IMDB but this will take me a while to get right. It's on my TODO list.
Ok cool, no worries.
My fault for not noticing the earlier post.....Sorry for that
OMG ... Noooooo !
Oh t|ts, I thought that or they banned my IP! Smile
(2015-12-04, 01:05)BobCratchett Wrote: The old Google image search api - long since deprecated - has now been discontinued, so all Google image searches by the script are failing. It's probably possible to switch it to the Google custom search api without too much difficulty, and indeed I'll give it a go myself over the weekend if I'm not beaten to it Wink
Oh damn... That's a shame.
Isn't it true that the dev API key allows you to request 100 images each day per IP ?
In that case it isn't that bad.
I will have to read through the Google docs what the options are now.
Too bad they removed this, it was working quite well.
(2015-12-04, 16:38)marcelveldt Wrote: Too bad they removed this, it was working quite well.
Indeed ! I can't imagine having to do without TV scraper now :/
(2015-12-04, 16:55)Jayz2K Wrote: Indeed ! I can't imagine having to do without TV scraper now :/
For the time beiing you can use the YouTube scraper but that was is a bit slow.
I think we can figure something out with the google images.
I haven't gone too far into the documentation - but I saw that the 'Pricing' section on the following page - https://developers.google.com/custom-sea...1/overview - doesn't talk about it being per-IP and quickly moved on!
(2015-12-06, 02:28)BobCratchett Wrote: I haven't gone too far into the documentation - but I saw that the 'Pricing' section on the following page - https://developers.google.com/custom-sea...1/overview - doesn't talk about it being per-IP and quickly moved on!
Well, the only option I see is to let users insert their own personal API key if they want to use Google searches.
OR: Use the regular google images website and scrape the results. A pain to code but it will work.
At least the IMDB/fanart.tv options are still working.
Don't want to put a downer on this - especially as I have confidence you'll find a solution - but (from my reading) the user wouldn't just require an API key but also a search engine ID. Instantly makes it 2x as hard to do, and - as I've said previously - probably against Google's TOS. Regarding scraping results - I already regularly get Catchpa's from Google as - apparently - my searching may be suspicious. Not that this would necessarily be a problem, but handling Catchpa's is something you'd need to handle.
I really don't want to be seen as being negative on this, more inserting an element of realism. It's do-able (especially by someone as talented as you), but there are issues that need to be addressed Smile
edit: offtopic Smile
1.0.22 in beta repo breaks cast, this version ok https://github.com/marcelveldt/script.sk...3f5aa8f468
13:00:50 T:5764 NOTICE: Skin Helper Service --> Parameter string: ?action=getcast&movie=220
13:00:51 T:5764 ERROR: Skin Helper Service --> Error in plugin.py --> 'id'
13:00:51 T:5764 ERROR: Traceback (most recent call last):
13:00:51 T:5764 ERROR: File "C:\Users\danrach\AppData\Roaming\Kodi\addons\script.skin.helper.service\plugin.py", line 113, in <module>
13:00:51 T:5764 ERROR: Main()
13:00:51 T:5764 ERROR: File "C:\Users\danrach\AppData\Roaming\Kodi\addons\script.skin.helper.service\plugin.py", line 88, in __init__
13:00:51 T:5764 ERROR: getCast(movie,tvshow,movieset,episode,downloadthumbs)
13:00:51 T:5764 ERROR: File "C:\Users\danrach\AppData\Roaming\Kodi\addons\script.skin.helper.service\resources\lib\PluginContent.py", line 986, in getCast
13:00:51 T:5764 ERROR: liz.setProperty("DBID",cast["id"])
13:00:51 T:5764 ERROR: KeyError: 'id'
13:00:51 T:3356 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://script.skin.helper.service/?action=getcast&movie=220
13:00:51 T:2064 NOTICE: Skin Helper Service --> Parameter string: ?action=getcast&movie=220
13:00:52 T:2064 ERROR: Skin Helper Service --> Error in plugin.py --> 'id'
13:00:52 T:2064 ERROR: Traceback (most recent call last):
13:00:52 T:2064 ERROR: File "C:\Users\danrach\AppData\Roaming\Kodi\addons\script.skin.helper.service\plugin.py", line 113, in <module>
13:00:52 T:2064 ERROR: Main()
13:00:52 T:2064 ERROR: File "C:\Users\danrach\AppData\Roaming\Kodi\addons\script.skin.helper.service\plugin.py", line 88, in __init__
13:00:52 T:2064 ERROR: getCast(movie,tvshow,movieset,episode,downloadthumbs)
13:00:52 T:2064 ERROR: File "C:\Users\danrach\AppData\Roaming\Kodi\addons\script.skin.helper.service\resources\lib\PluginContent.py", line 986, in getCast
13:00:52 T:2064 ERROR: liz.setProperty("DBID",cast["id"])
13:00:52 T:2064 ERROR: KeyError: 'id'
13:00:52 T:3356 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://script.skin.helper.service/?action=getcast&movie=220
@marcelveldt, translation script for portuguese (brazil), thanks
http://files.xbmcbrasil.net/Scripts/Scri...razil).zip
MediaBrazil forum Website - Youtube Channel
Aeon MQ8 & Ace2-1.1.0 Skin Team - MarcosQui Website uses to Donate and support us.
Hi Marcel,
With regards the broken cast widget, I can see that you were trying to add the episode/tvshow or movie dbid to the cast item but the logic is wrong. Would you like me to submit a PR to fix it or are you planning to resolve it and put a new build up on the Emby beta repo? Cheers
For the library window properties, can we also get budget info? Angel
(2015-12-12, 21:13)Fail$tyle420 Wrote: For the library window properties, can we also get budget info? Angel
Yeah check out the RottenTomatoesBoxOffice property.
  • 71
  • 72
  • 73(current)
  • 74
  • 75
  • 270
  • 18 Vote(s) - 4.56 Average
skin helper service4.5618
