(2016-03-16, 10:42)Mike_Doc Wrote: This worked for me in webbrowser http://localhost:52307/getanimatedposter...=tt1345836 but like I said only give static without fallback, with fallback I always get poster
Confirmed. Can't be fixed. Kodi doesn't support the animated gifs from a http path.
Only workaround is by using the special://thumbnails path but downside of that is the errors in the log.
What I can do is make it available as ListItem.Art(animatedposter) with an optional setting to write the details to the Kodi db.
It's something @BobCratchet requested some posts back.
(2016-03-17, 20:31)Angelinas Wrote: fix that, this info are missing to me ....
Should now be fixed on Git. While solving the lockdown issue I removed a little too much of code.
It's all OK now and running smooth
Think Bob summed it up perfectly Marcel.
If you can create .ART() for all images in SHS then that would be simply amazing.
Also, meowmoo asked about the possibility of using local artwork with regards to Music, for say artist logo and CDart?. Those of us few that use Kodi for Music have added all these images to the folders etc. etc. and use the hacks to get to them, but if possibly could you check for local and use that and then for fallback use the internet which I believe is what you do now? and of course like Bob said possibly make them as .ART() properties as well?
Thanks for considering either of the above and for the time you'll spend on them, much appreciated Marcel.
SKIN: Aeon Madnox
RIP Schimi2k, we miss you.
When I grow up I want to be a skilled skinner
Thank me by ⬇ adding to my + reputation
Hi Marcel,
I have a query on the recent animated posters / backgrounds calls. It seems some movies have multiple entries for either poster or background so i was wondering if it is in anyway possible to show a select dialog of all the posters / backgrounds so the user can choose which to download to animatedgifs and then the calls use the cached image?
SKIN: Aeon Madnox
Jayz2K
Skilled Skinner
Hi Marcel, I have a small functional change request regarding the color picker :
Actually, the color window property is set at color "onfocus" and navigation forwarded to "save" button at "onclick".
Works pretty well using keyboard, however it doesn't using mouse.
If you highlight a color in the panel and want to change the opacity, you need to fly over other colors to reach the slider control and the Color's window prop value changes. So you never manage to get the wanted color if it's not one from the edge of the panel. An easy fix could be to set the property at onclick like the button forwarding. Highlighted value can still be shown using Container.ListItem.Label.
Mind to have a look at this ?
Thx.
[Skin] KOver - V1.1.0 Stable (Repo version)
[WIP] ReKOver - Skinning tool project
If I've been helpful or you like my work, hit "THANK USER" button ;) ...
(2016-03-17, 20:38)tomer953 Wrote: Hi,
feature request:
same like "Toggle Kodi Settings"
but for strings and not for booleans. (ie: locale.language - resource.language.en_gb)
Added to my TODO list for next week ;-)
https://github.com/marcelveldt/script.sk.../issues/43
(2016-03-18, 14:03)Mike_Doc Wrote: If you can create .ART() for all images in SHS then that would be simply amazing.
Well, it's not going to be that easy... For video items it's no issue as I can use the json api to write the additional artwork to the kodi db.
For music items it's going to be complicated because the json api doesn't have support to write artwork to the kodi db. We will have to request that to the Kodi devs as I'm not capable of submitting a PR to add this to the Kodi code (maybe someone with C++ experience reading this and likes to jump in?)
(2016-03-18, 14:03)Mike_Doc Wrote: Also, meowmoo asked about the possibility of using local artwork with regards to Music, for say artist logo and CDart?. Those of us few that use Kodi for Music have added all these images to the folders etc. etc. and use the hacks to get to them, but if possibly could you check for local and use that and then for fallback use the internet which I believe is what you do now? and of course like Bob said possibly make them as .ART() properties as well?
The logic is already like that. The script prefers local artwork found in the media folders. It expects a traditional folder structure:
PHP Code:
----your music folder
------ ARTIST
------------------ extafanart
------------------ ALBUM
etc.
Maybe some users have their artwork scraped into a different folder? In that case I can add an additional setting to look for the artwork in that custom folder.
(2016-03-18, 18:33)Angelinas Wrote: Noop, same as beffore....Only difference is that When I press refresh item (auto lookup),that items stay for next chanel (clear.property not working)
Can you grab the latest version from Git ? Should now all be fixed. Finally found the real underlying issue for the problems.
