Really nice screensaver, full of features, but I'm using a 4.3 inch tft screen to use as a clock on my desk, and the clock is tiny and quite annoying having to follow it around the screen to read.
I know this has been requested a couple of times, but is there any chance that you could put an option in to leave the clock in the centre of the screen, even if it has to contain a warning. I know you have an issue with screen burn, but I've been using a similar screensaver for over a month now, and not noticed any damage to pixels on the screen, and with it only being a £10 screen, it's not really any harm done if anything does ever occur.
Also I know users have been requesting if you could enlarge the size of the clock and as you mention it has something to do with fonts. I was wondering if the circumstances had recently changed that would allow you to get around this (anychance maybe the system display zoom feature can be activated when the screensaver kicks in, might be easier to do if the time is always stationed centre on the screen to stop edges being clipped).
Honestly, if you can sort these two little niggles out, I'll happily send ya fiver as I'd love nothing more than being able to have a desk clock with weather/date/now playing.
Regards,
Sorry, i forgot to mention in the previous post that I was using OSMC skin. Do you know of any skins that do use a large font?
Thanks for the quick reply.
vdb86
Senior Member
2016-03-18, 10:02
(This post was last modified: 2016-03-24, 18:45 by vdb86.)
It should work just fine with OSMC skin.
I've added fixed center screen position, let me see if I can do anything with zoom.
Zoom is kinda tricky since it literally enlarges everything and stuff can become pixelated or have some other artifacts.
Hi. Is it possible to show the album cover in the now playing infoline?
this is a nice screensaver.
I checked all the options and I have one question.
I know I can put the clock in the middle.
Is it also possible to have the clock for example in the right upper corner or another position?
I would like the use the slideshow and don't wnat to have the clock in the middle and also not random on the screen.
2016-12-11, 17:26
(This post was last modified: 2016-12-11, 17:27 by treeby.)
I have 2 Kodi systems running on 2 different android tv boxes
on both the displayed time from sreensaver is 1 hour wrong,
where can i change this setting ?
2016-12-12, 23:36
(This post was last modified: 2016-12-12, 23:38 by SilentStrike.)
Hey ddb86,
First off, gotta say I love the background! Very simple, and well done!
However, I've encountered a bug I thought I'd share with you. Well... Bug/not as the software intended, but I'm sure I might be the only one to try and do this.
Basically, if I set a background folder and there are multiple images, everything works fine, but if I set a folder with only a single image, the plugin will freeze whenever it starts looking for the next picture (and can't find it).
Maybe you could add a check for how many files and just skip the "slideshow" if it doesn't find multiple images.. Or maybe just add a choice box for single image background or something. Just ideas on how to fix it!
Edit: I also noticed another bug.. If the contents of the folder has changed since either Kodi was reset, or the specified folder has been reset, it won't show a background. It'll just show black.
