Koying
Retired Team-Kodi Member
@wrxstasy Thanks. Indeed, the 23.976 and 29.970 modes are not exposed.
fritsch
Team-Kodi Developer
2016-02-09, 17:52
(This post was last modified: 2016-02-09, 17:52 by fritsch.)
I still consider fixing the FrameRate Automation a minor thing (e.g. not too hard to do)*. We had such issues on AMD / Intel in the past years and after they counted these values more properly everything was working fine. Never the less, the current switch to 23.976 hz is a hack and that also needs to be solved.
* Needs someone that can compile the kernel and test a bit.
First decide what functions / features you expect from a system. Then decide for the hardware. Don't waste your money on crap.
