Full Version: WeTek Core (24p HD Netflix / HD Audio / Lollipop / OpenELEC / 4K / HEVC)
RE-EDIT: 25th May 2016
OTA Wetek Core OS 1.2 released HERE
WeTek Core:
WeTek Core website HERE
98 EURO / $107 USD inc free delivery (export pricing for shipping outside the EU)
Description:
Fast, 8-bit / 4K / 1080p / H264 / HEVC / DRM Video Streamer / Kodi / IPTV media player, running Android Lollipop 5.1.1 or a dual boot Android / OpenELEC combo.
Features:
  • Excellent Motion Adaptive video de-interlacing for broadcast TV viewing.
  • Super responsive RF / IR Wireless Remote control, that includes an accurate Air Mouse function and Microphone
  • Standby Mode, device can be powered ON/OFF using IR on the remote control.
  • OTA (Over the Air) Android Firmware updating
  • Properly synced 23.976/29.97/59.94Hz video output for smooth video playback
  • Includes dynamic refresh rate switching when using Kodi, based on source video's fps.
  • Netflix and Google Widevine Level 1 DRM certified for full 1080p HD video streaming, all other AMLogic and Rockhip Android media players are limited to 480p Max resolution for DRM Netflix and other Apps....
  • Dolby and DTS licensed device.
  • Android TV OS versions of Netflix and YouTube and other Apps, work on the Core as well.
WeTek Core Special Features:
  • Customised WeTek Jarvis 16.0 mediaplayer, based on Kodi Jarvis to allow for HD Audio + Kodi AMLogic specific bug fixes. (Android only currently)
  • 7.1 HD Audio Passthrough (Bitstreaming - Android only)
  • 7.1 HD Audio decoded to bit perfect, lossless Multichannel PCM Audio (Android only)
  • Latest HD Audio passthrough tests by hdmkv with the WeTek Jarvis 16.0 mediaplayer HERE
  • Easily customisable, slick, WeTek Android Desktop Launcher.
  • Dual boot Android / OpenELEC, selectable from the remote control during a reboot.
  • Slick WeTek IPTV App.
  • Customisable 24p App Refresh Switcher, for nicely synced 23.976fps Netflix and other video streaming Apps.
  • TvHeadend Server ported to the Core and works in Android if you like a bit of DIY.
  • HDMI CEC control of AVR's from both within Android and OpenELEC
Known issues:
  • VC-1, 29.970fps interlaced content (very slight juddering), a lot of media players have issues with this combo.
    Sample HERE, VC-1, 23.976fps progressive plays just fine
  • Rare, unusual Variable Frame Rate HEVC has been known to cause playback issues
  • Netflix audio is 2.0 only due to some stupid Netflix restriction.
  • Some Apps will only work when connected over WiFi.
  • The 24p selectable App Refresh switcher is not 100% foolproof due to an Android OS limitation. Some UK/EU/AUS Netflix content is 25/50fps and incompatible with this 24p App.
    Simply deselect Netflix for refresh switching in those cases.
  • Potential purchasers should always read the WeTek Core support forums found HERE
  • The Power Cord needs to be longer, at least 1.5-> 2 metres
  • No Power brick click in adapter included for us down under, AUS/NZ, convicts and Hobbits Wink
  • HBO GO will not work as if requires Microsoft Playready DRM which the Core does not have a licence for. Confirmed Working.
User Tips:
  • New User Remote Control Tips - Click HERE
  • Kodi Keymap Editor - Click HERE
  • Map back button to Stop function during Full Screen Video Playback only - Click HERE
  • Latest Test Firmware for Android Universal Dynamic Refresh Rate Switching See this Post
  • Android TV launcher remote control friendly Apps for the Core Click HERE
A WIP:
  • Android - Universal Dynamic Refresh Rate switching for any Android video playback App, eg Netflix, YouTube etc. The same dynamic video sync functionality as Kodi. All Automatic. An awesome feature IMHO for those that like smooth video playback. (final stages of testing now.)
  • WiFi spoofing, so badly coded WiFi only Apps can use a Ethernet connection.
  • Half Resolution 3D MVC, with 3D auto switching function to switch the TV into 3D mode seamlessly.
  • hdmkv's 3D MVC test results HERE
  • HD Audio or decoded HD to Multichannel PCM Audio Output when using OpenELEC. 5.1 DD/DTS does work.
  • A new AMLogic decoder, written by WeTek for future Kodi 17.0 Krypton compatibility.
  • Pulse8 libCEC compatibility in OpenELEC, to control an AVR's volume from the TV remote (final testing right now)
  • Experimental 3D MVC Playback with Koying's SPMC, a version of Jarvis 16.1. SPMC will not overwrite Kodi or WeTek's Jarvis mediaplayer.
Conclusion:
This is a Slick little device, just slightly bigger in size than an Apple TV 3 and perfect if you want a dual boot Android Lollipop / OpenELEC device that also does 23.976fps HD Netflix and 23.976fps HD video in other copy protected, paid Android video streaming Apps.
You won't get auto 23.976fps HD Netflix video sync on even the new NVIDIA Shield. Its a pleasure to watch.
This is a world first for an AMLogic device and is the best of both OpenELEC and Android worlds in one well sorted media player.
The WeTek guys really know what they are doing with their Software and more importantly - Firmware.
WeTek are both a Kodi and OpenELEC sponsor, and it definitely shows in the passion they put into their products.
Three Thumbs Up ! Smile Smile Smile
Tech Specs:
  • CPU: AMLogic S812-H / up to 2GHz Quad core
  • GPU: Mali-450MP / Octo-core
  • ROM: 8GB NAND
  • RAM: 2GB
  • LAN: Gigabit Ethernet
  • WiFi: Broadcom AP6330 802.11 b/g/n - 2.4/5 GHz
  • Bluetooth 4.0
  • Optical: S/PDIF
  • Remote: RF + IR with Microphone for Google Voice
  • HDMI CEC Control
  • HDMI 1.4a
  • Power Adaptor for UK, USA and EU
    http://www.amlogic.com/#Product/190/index.html
Confirmed price of 98 EURO / $107 USD (ex. taxes - 9th December 2015)
More Reviews:
Really interesting product.
From the videos, it looks like it is Android TV OS (Leanback launcher), but from Christian's posts on WeTek forum it seems like it is running regular Android 5.1.1. Novel way to implement 24Hz auto switch for apps. Minix resorted to something different and it doesn't work with protected streaming. If there is a stutter every 90-120s, it suggests that the actual refresh rate could be 23.964-23.987Hz.
Nice looking device, what about 3d iso support and hd audio?
@wrxtasy
Thanks for Core introduction Smile
We are working fast to release device, iand t should be available from the next month. Just we want to be sure that everything is fine, and there are some ongoing certifications.
@Skank
3D ISO we will test and let you know ASAP, regarding Audio device support Dolby and DTS and we use S812-H version of AMLogic SoC.
(2015-09-18, 18:11)droidelec Wrote: [ -> ]@wrxtasy
@Skank
No HD Audio?
(2015-09-18, 18:18)movie78 Wrote: [ -> ]
@Skank
No HD Audio?
Amlogic S812-H has Dolby Digital Plus (5.1) and DTS-HD (M6) decoder licenses. DTS M6 license only allows coreless DTS-HD Master Audio (it is a streaming only format and you will never see this on a physical media).
(2015-09-18, 19:02)wesk05 Wrote: [ -> ]
@Skank
No HD Audio?
you mean if support Audio HD passthrough?
(2015-09-18, 22:58)looun Wrote: [ -> ]you mean if support Audio HD passthrough?
No, it just means that the license permits coreless DTS-HD Master Audio track to be bitstreamed. The format doesn't exist on commercial media.
@Skank
No HD Audio?
So no Dolby TrueHD license right?
(2015-09-19, 00:56)BORIStheBLADE Wrote: [ -> ]
(2015-09-18, 18:18)movie78 Wrote: [ -> ]No HD Audio?
No Dolby TrueHD = fail.
Sorry, must have both for me to consider it..
So - does the Wetek not support Dolby True HD OR DTS HD MA/HRA (with core) pass through?
Given that DTS HD Coreless is unheard of 'in the wilde', and not used on Blu-ray, this sounds a bit disappointing?
Does it implement DTS HD and Dolby True HD decoding to PCM with multichannel PCM output as the Pi 2 does?
(2015-09-19, 11:13)noggin Wrote: [ -> ]So - does the Wetek not support Dolby True HD OR DTS HD MA/HRA (with core) pass through?
Amlogic S812-H natively cannot bitstream/decode DTS-HD Master Audio or High Resolution Audio. It is a licensing restriction. According to Minix/Amlogic, the SoC can support multichannel PCM (only 6 channels), but it has been disabled by Amlogic (? licensing restrictions). Kodi may support HD audio passthrough on WeTek Core if they have done something like VidOn. This is something that WeTek has to clarify.
I think it will be easy to just say no it doesn't support HD Audio.
No HD Audio
No 3D MKV or ISO support.
I'm OUT!!
For those that want a bit of sensible info, minus the Marketing Hype, on 3D and HD Audio and how it really is not that important in a casual use, non theatre setup Kodi box, (especially if you don't have high quality speakers) Have a read of the following threads...
http://forum.kodi.tv/showthread.php?tid=...pid2116393
http://www.avsforum.com/forum/149-blu-ra...-hoax.html
This quote succinctly sums up the HD Audio discussion:
(2015-09-30, 20:36)Soli Wrote: [ -> ]Sorry for coming in a little late...
I think you are, excuse the expression, blowing steam up your own ass.
This is looking more interesting now that I've returned my fire tv 2.
The product page is up: https://wetek.com/product/wetek-core
It's not on their store page yet.
Do you think this is able to decode 1080p h.264 hi10p without stuttering?
And it says it supports "8-bit H265." Does this mean only software decoding for main 10?
