2018-03-30, 04:48
Im using Blue Iris with this add-on right now i just set it up today. Only issue ive had was a wonky issue where i cant get my camera 1 to work in PiP but works fine elsewhere.
In blue iris go to settings>web server. At the bottom make sure the dropdown box for Authentication has "Non-LAN only" and make sure "secure only" is unchecked.
In kodi make sure you select
source-player mjpeg
source-preview snapshot
for the URLS mine are just written in like so
Snapshot URL- http://192.168.0.10:8087/image/Cam1
MJPEG URL - http://192.168.0.10:8087/mjpg/Cam1
This should get the streams and snapshots working for you but like i said i have a weird issue where it will not play cam1 in PiP but plays the others just fine. Then when i go into the 4 way grid of my cameras only cam1 will work while the others dont. Maybe someone else could help me with this part? I have previews checked for each camera so im not sure what could be the problem.
source-player mjpeg
