I have the same issue.. worked fine until few weeks back, now i cant play live sports section.
Let me know if there is a fix.
Here's a snippet of my log if it helps.
09:32:54 T:1563737664 ERROR: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.requests/lib/requests/packages/urllib3/util/ssl_.py:315: SNIMissingWarning: An HTTPS request has been made, but the SNI (Subject Name Indication) extension to TLS is not available on this platform. This may cause the server to present an incorrect TLS certificate, which can cause validation failures. For more information, see
https://urllib3.readthedocs.org/en/lates...ingwarning.
SNIMissingWarning
09:32:54 T:1563737664 ERROR: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.requests/lib/requests/packages/urllib3/util/ssl_.py:120: InsecurePlatformWarning: A true SSLContext object is not available. This prevents urllib3 from configuring SSL appropriately and may cause certain SSL connections to fail. For more information, see
https://urllib3.readthedocs.org/en/lates...ormwarning.
09:32:55 T:1563737664 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.IndexError'>
Error Contents: list index out of range
(2016-01-30, 06:15)sunmun Wrote: (2016-01-29, 16:31)yocoldrain Wrote: (2016-01-29, 11:42)sunmun Wrote: Could anyone confirm if you are able to see the live games. I could see these games on my computer using modheader extension to change my proxy but if I put the same proxy in the add-on settings, I get hotstar error. Thanks for your help.
watched cricket t20 today.
Thanks @ycoldrain. Strange that it is not working on my setup, whereas it was working fine till 2-3 weeks back. I will figure it out myself. Thanks for your great work @ycoldrain.
