2017-05-17, 13:45
(2017-05-17, 13:18)Bjur Wrote: Okay thanks I will consider what to do. But are the BETA working absolutely fine and still have many of the same things as the alpha?
The 1.4.7.x Beta is WAYS back in development and no longer supported. I thought you wanted to use an older alpha version that worked for you.
I've to change our (crappy) version designations to help the users to understand which one is working or stable as possible.
Next release will be called 1.5.0 Beta (will be released in next 10-14 days).
That means all features are possible features has been implemented, so we have feature freezed state and I will only fix very bad issues they need to be fixed.
I'm already working on Ember v.2.0 that has been reworked at most of all core funktions, core code and modules/addons. A part of the features that I've promised for Alpha 24 will be only included in the first 2.x release. Sorry for that, but I did not expect it needs so many changes and optimizations.
It is absolutely nonsense to add new features and fix the same errors and problems on two versions.
At the moment, I'm just updating the bug tracker and adding all the steps to the milestones, so you have a little overview of the current state.
