Can an admin tell me why I've been IP-banned?
I can login to the forums from outside my home network, but get a "you've been banned" message from my home network.
are you using a VPN, maybe is the IP used.
Are you able to release your home IP then obtain hopefully a different one?
da-anda
Team-Kodi Member
if you PM your IP I can have a look and remove it from the blacklist.
nickr
Retired Team-Kodi Member
Maybe someone was spamming from your IP address
If I have helped you or increased your knowledge, click the 'thumbs up' button to give thanks :) (People with less than 20 posts won't see the "thumbs up" button.)
