Hi..
#0614, 14-Jun-2016: RPi / RPi2
MCE Remote not work... Problem with new lirc?
Hello,
Like mentioned in post #888 I also don't get any options in LibreELEC -> System. Only Network, Connections etc. shows options. The same seems to be the case with LibreELEC (Krypton) v7.90.002 ALPHA.
I don't have this issue in LibreELEC (Jarvis 16.1) v7.0.1 and all builds up to LibreELEC-RPi2.arm-8.0-Milhouse #0609. Later builds all have this issue.
Anyone have any clue? I have a RPi 3.
When does it auto updates?
i have 614 on it.
i have it set to auto update.
When does it check for updates? on shutdown/restart/bootup?
I have restarted many times and installed different images to check which worked an which not. As mentioned all builds work up to #609. So I guess something has changed since then ...
