2016-05-08, 14:57
505x and Braswell NUC, few houra now tested and all ok, no freezes so far.
(2016-05-08, 11:53)MariusB Wrote: This is strange because this command worked earlier today with the build #0506.
What am I doing wrong?
LibreELEC (community) Version: devel-20160506005756-#0505x-ga066054
LibreELEC git: a066054ab61f194dd53a846750f11f24eab498af
LibreELEC:~ # paste $(ls -1art /storage/.kodi/temp/kodi_crashlog* | tail -1)
ls: /storage/.kodi/temp/kodi_crashlog*: No such file or directory
(2016-05-08, 15:21)M4tt0 Wrote: @Milhouse or @fritsch,
I just got HD+ and with that access to the Astra UHD (test) channel. I'm on a HSW i5 NUC (#505x) and gave it a run, downscaling to 1080p via lanzos3 (no 4k TV). The video stutters significantly. No chance with the HSW on linux-based systems, right?
(2016-05-08, 01:45)Milhouse Wrote: Are you testing with stock Estuary?
1) Screenshot example? Do you mean the position in the GUI or the value being displayed?
2) Screenshot example? Not seeing this myself, have you muted audio?
3) What is the "audio" button, is this an action you've mapped on your remote? A debug log might help.
4) A debug log might help.
5) You probably need an updated add-on - these are alpha builds so breakage due to updated libraries is to be expected.
(2016-05-08, 19:45)witek666 Wrote: So should I write to LibreElec due to official work and work for the release of April 21 ?
As add -ons it will work on the version of 21 April ?
(2016-05-08, 19:11)walkerx Wrote: 1) was to do with the values which are now resolved
2) yes I had muted and then reenabled audio so was displaying speaker
3) had switched audio on/off
4) issue no longer present in 507
5) yeh currently just projectm having problem, so uninstalled
(2016-05-08, 15:47)Milhouse Wrote: You're not doing anything wrong, you simply don't have any crashlogs to upload, which indicates Kodi hasn't crashed since installing #0505x. You did have a crash under #0506 but assuming you did a clean install of #0505x this would have erased all previous #0506 crashlogs, and there's now nothing to upload.
dmesg | pastebinit
journalctl -a | pastebinit
cat /storage/.kodi/temp/kodi.log | pastebinit
vainfo | pastebinit
cat /var/log/Xorg.0.log | pastebinit
# uname -a
Linux LibreELEC 4.6.0-rc6 #1 SMP Sun May 8 21:18:07 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160508211119-#0508-g7becc33 [Build #0508]
