20 Nov 2019 - TVDB Scraper v3.2.0 is now available which reinstates scraping. TVDB are still in the process of fixing a number of bugs so there may still be further breakages. See this post. 2901570 (post)
  • 37
  • 38
  • 39(current)
  • 40
  • 41
  • 187
  Thread Closed
v17 LibreELEC Testbuilds for x86_64 (Kodi 17.0)
(2016-05-23, 00:34)smitopher Wrote: I have a NUC5PPYH with the Brasswell Pentium N3700 processor. I put it in Akasa fanless case.
I have a habit of feeling it to see if the fanless case is doing the job.
While running LE 7.0, when idle, it is barely above cold. After watching a 2 hour movie just warm.
Running build 518,
It gets very warm while idle and borderline hot while viewing a movie.
When debug mode is on, and idle, it reports the CPU as very busy, of 50% average of all cores.
I surmise that there are still race conditions in the Kernel when running on Brasswell.
Nobody can help you without a Debug Log. But yeah, if you want speculations. Here is another one: Stop intrusive scripts while watching videos :-)
First decide what functions / features you expect from a system. Then decide for the hardware. Don't waste your money on crap.
(2016-05-23, 10:26)aesthetiker Wrote: Since I upgraded from openelec to librelec.
This is absolutely of no help.
(2016-05-23, 10:26)aesthetiker Wrote: Tried to uninstall pvr.hts reconfigure etc no changes to this behavior.
The add-on is built-in, trying to uninstall it won't work.
If you want a fix you'll need to determine when the problem starts (ie. identify the first build with the problem).
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
With ref to this 100% CPU and Nvidia issues mentioned a few weeks ago:
I also have issues with my Nvidia system (ASrock V3D - i3M 370 / GT425M), too. I tested kodi17 build #0522 upfront finally downgrading to 13.2. Don't know if this is of much help, but anyway, here is what I have
Issues were:
- CPU 100% > during playback
- kodi crash during idle in main menu ..
- kodi crash during video playback (HD PVR and mkv)
- kodi logs did not show anything interesting
- I did experience this on this nvidia system w/ 16.1, too (w/ OE 7b3 and LE 7.01). The NUC system I have does not behave like this and runs smoothly w/ 16.1
dmesg showed this:
[    9.007680] snd_hda_intel 0000:01:00.1: IRQ timing workaround is activated for card #1. Suggest a bigger bdl_pos_adj.
[  492.190152] perf: interrupt took too long (2503 > 2500), lowering kernel.perf_event_max_sample_rate to 79800
[  536.507317] kodi.bin[977]: segfault at 0 ip           (null) sp 00007fff7422a448 error 14 in kodi.bin[400000+1617000]
[  721.954269] perf: interrupt took too long (3140 > 3128), lowering kernel.perf_event_max_sample_rate to 63600
[  863.307029] perf: interrupt took too long (3932 > 3925), lowering kernel.perf_event_max_sample_rate to 50700
[ 1180.052802] perf: interrupt took too long (4916 > 4915), lowering kernel.perf_event_max_sample_rate to 40500
[ 1222.543830] kodi.bin[1195]: segfault at 0 ip           (null) sp 00007ffd4ba3b368 error 14 in kodi.bin[400000+1617000]
[ 1534.976751] traps: kodi.bin[1397] trap invalid opcode ip:7f002e72c310 sp:7ffea3ce59e0 error:0 in libnvidia-glcore.so.352.79[7f002d07e000+19fe000]
[ 2155.187528] traps: kodi.bin[1529] trap invalid opcode ip:7fc859128310 sp:7ffc310c6c20 error:0 in libnvidia-glcore.so.352.79[7fc857a7a000+19fe000]
[ 2200.422024] traps: kodi.bin[1741] trap invalid opcode ip:7ffb7ce62310 sp:7fffbb64b3c0 error:0 in libnvidia-glcore.so.352.79[7ffb7b7b4000+19fe000]
[ 2206.649060] traps: kodi.bin[1858] trap invalid opcode ip:7f3a660e1310 sp:7fffb1ef1cb0 error:0 in libnvidia-glcore.so.352.79[7f3a64a33000+19fe000]
[ 2212.498426] traps: kodi.bin[1933] trap invalid opcode ip:7f433b4db310 sp:7ffef82c2950 error:0 in libnvidia-glcore.so.352.79[7f4339e2d000+19fe000]
[ 2217.061849] traps: kodi.bin[2034] trap invalid opcode ip:7f79ce1f9310 sp:7fff54e69330 error:0 in libnvidia-glcore.so.352.79[7f79ccb4b000+19fe000]
[ 3500.305670] traps: kodi.bin[2109] trap invalid opcode ip:7f2df104d310 sp:7fff83e92c40 error:0 in libnvidia-glcore.so.352.79[7f2def99f000+19fe000]
[ 3505.964013] kodi.bin[2363]: segfault at 0 ip 0000000000da9f04 sp 00007fffb0070968 error 6 in kodi.bin[400000+1617000]
[ 3510.903861] kodi.bin[2395]: segfault at 0 ip           (null) sp 00007ffc0abfce28 error 14 in kodi.bin[400000+1617000]
[ 3516.323814] kodi.bin[2494]: segfault at 0 ip           (null) sp 00007fff96fc9df8 error 14 in kodi.bin[400000+1617000]
[ 3521.561607] traps: kodi.bin[2594] trap invalid opcode ip:7f9c07075310 sp:7fffeb550890 error:0 in libnvidia-glcore.so.352.79[7f9c059c7000+19fe000]
[ 3525.658251] kodi.bin[2684]: segfault at 7ff19a3921b8 ip 00007ff1b25747cf sp 00007ffc3a0c6310 error 7 in ld-2.23.so[7ff1b2569000+23000]
[ 3532.381188] traps: kodi.bin[2724] trap invalid opcode ip:7f5696163310 sp:7ffd6c423660 error:0 in libnvidia-glcore.so.352.79[7f5694ab5000+19fe000]
[ 3533.600442] traps: gdb[2800] general protection ip:482b82 sp:7ffdd559c4e0 error:0 in gdb[400000+4e6000]
[ 3567.410481] traps: kodi.bin[2823] trap invalid opcode ip:7f5907bbb310 sp:7ffd015ff100 error:0 in libnvidia-glcore.so.352.79[7f590650d000+19fe000]
[ 4013.517623] traps: kodi.bin[2936] trap invalid opcode ip:7f940af0c310 sp:7fffdc296b40 error:0 in libnvidia-glcore.so.352.79[7f940985e000+19fe000]
[ 4267.839626] traps: kodi.bin[3217] trap invalid opcode ip:7efd8b88b310 sp:7ffc105c40c0 error:0 in libnvidia-glcore.so.352.79[7efd8a1dd000+19fe000]
[ 4524.873350] traps: kodi.bin[3319] trap invalid opcode ip:7f326d0af310 sp:7ffe4a56b000 error:0 in libnvidia-glcore.so.352.79[7f326ba01000+19fe000]
both segfaults during video playback (HD channels w/ vdr backend)
1534 ff. kodi idle in main menu. the following during navigation to play some video files ..
2217 At least I'd start a video ...CPU ~115% with at least one cpu core (jumping between them) at 100%
3500 ff. The final reboot loop happened after I stopped a x264 video playback for ~15 minutes and getting back to main menu. There were 5 reboots after I was 'save' in main menu again.
3567 ff. during idle in main menu
The latst crashlog:
http://sprunge.us/dEMW
Besides, in case this doesn't provide any significant input. Kryton looks and feels good! I think I need to prepare an usb drive to test krypton on the nvidia system without reinstall .. now going to restore my 13.2 backups; wife is back from vacation.
Milhouse or fritsch any chance you guys could look into my dropped frames issue? I found that #0411 is last build that does not have frames dropped problem and choppy playback. I have all video settings set as recommended in fritsch's thread. I have this install on nuc hsw if that helps to clarify things.
Here is debug for Build #0522. : debug
(2016-05-23, 16:30)lazyman Wrote: With ref to this 100% CPU and Nvidia issues mentioned a few weeks ago:
Issues were:
dmesg showed this:
The latst crashlog:
Nvidia binary bug:
Quote:0x00007f326d0af310 in ?? () from /usr/lib/libnvidia-glcore.so.352.79
(2016-05-23, 16:30)lazyman Wrote: Issues were:
I guess this is the same problem affecting both the legacy and non-legacy Nvidia driver.
(2016-05-23, 16:30)lazyman Wrote: - kodi crash during idle in main menu ..
The OE7/LE7 builds (Kodi 16.1) and these 17.0 test builds all use the same 352.79 Nvidia driver, and something in Kodi clearly triggers a fault.
Again this would be one for Fernet, I think, but it's a new one on me - I've never seen this before (maybe we don't have enough Nvidia 352.79 users/testers).
Running build 518,
Addon's that I have loaded
MythTv PVR
HDHomerun
Amazon Prime https://github.com/liberty-developer/plu...me_instant
Weather Underground.
Which one is intrusive?
I'll generate a debug log if it is helpful to identify what is making the cpu work so hard.
Hi guys, even the restore to 13.2 surprised me after ~ 20 minutes running. I now think it's possible the Nvidia box has a HW problem - memory may be. Sorry for any hasty conclusion from my side with regard to the nvidia system. Please use some grains of salt regarding these crashed. Need to run a few test and let's see.
as this 100% CPU issue is affecting all Nvidia - Kodi 17 setups, Ubuntu, Arch, LibreElec, I did some tests with
other Nvidia driver revisions, 364.19, 361.42, ..., 358.16, 352.63, same result,
there must be some Kodi 17/VideoPlayer -> Nvidia issue.
Shall I link this thread to Mentas VideoPlayer development thread here or to FernetMenta/XBMC on Github?
I discovered, running Kodi windowed reduces the CPU consumption by rough 40%,
I use this temporary fix on my Ubuntu living room box,
@Milhouse is it possible to activate the windowed mode on LibreElec?
I think is was possible on OpenElec, but the option seems to be gone.
We removed an nvidia only hack lately, that would force VSYNC in a special way on these setups. But you should also have this high load in the menus without any video playing - is this correct?
(2016-05-23, 21:19)lazyman Wrote: Hi guys, even the restore to 13.2 surprised me after ~ 20 minutes running. I now think it's possible the Nvidia box has a HW problem - memory may be. Sorry for any hasty conclusion from my side with regard to the nvidia system. Please use some grains of salt regarding these crashed. Need to run a few test and let's see.
The last OE version based on Kodi 13.2 is OE 4.2 using the 340.32 nvidia driver.
Are you saying you have the same nvidia invalid opcode bug with the 340.32 driver? Or did you just restore your 13.2 settings on top of a build (OE/LE 7, #0522) with the 352.79 driver?
(2016-05-23, 19:19)fritsch Wrote: Nvidia binary bug:
I'll bump the nvidia driver version in tonight's build to 361.42 from 352.79.
@lazyman can you test the next build (#0523) and report if it fixes the crashes, or causes any new problems. Thanks.
(2016-05-23, 21:29)ragnaroek Wrote: @Milhouse is it possible to activate the windowed mode on LibreElec?
True windowed mode won't be enabled, but you can toggle fullscreen if you map the "FullScreen" action (on my MCE/Ortek-VRC1100 remote, this is mapped to the * [asterisk]) keypad button by default).
(2016-05-23, 21:38)fritsch Wrote: But you should also have this high load in the menus without any video playing - is this correct?
I'm only seeing high load (one CPU at 100%) during video playback. While navigating the Estuary GUI the CPU load is low/normal, definitely no high load.
Okay - then it's something else.
New LibreELEC.tv Krypton build #0523b: Generic
(Supercedes previous build)
# uname -a
Linux LibreELEC 4.6.0 #1 SMP Tue May 24 01:33:42 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160524013202-#0523b-g1647950 [Build #0523b]
Based on tip of LibreELEC.tv master (16479507, changelog) and tip of XBMC master (aa49b81c, changelog) with the following modifications:
  • Includes FernetMenta "VideoPlayer" patches
  • Includes latest kodi-platform master (c8188d82, ahead +4)
  • Includes latest libcec master (6d68d212)
  • Includes latest libnfs master (00d9ba15, ahead +19)
  • Includes latest p8-platform master (041a8c6c, ahead +1)
  • Includes latest addons: adsp.basic (2ae604e5, +8), adsp.biquad.filters (29bfe9d8, +3), adsp.freesurround (34f50406, +7), asplib (da66f517), inputstream.mpd (3ac19c39, +11), inputstream.smoothstream (32275717, +2), peripheral.joystick (83371862, +30), pvr.argustv (5f48dcec, +4), pvr.demo (0fa9e1d0, +4), pvr.dvblink (a92f1264, +5), pvr.dvbviewer (3d0bea9a, +4), pvr.filmon (8743511d, +4), pvr.hdhomerun (b5ce9309, +4), pvr.hts (acd1a6ac, +5), pvr.iptvsimple (7a5a43f8, +4), pvr.mediaportal.tvserver (172a273c, +4), pvr.mythtv (e2b60252, +8), pvr.nextpvr (150698b7, +4), pvr.njoy (b5d65655, +4), pvr.pctv (feed5990, +4), pvr.stalker (dc112316, +6), pvr.vbox (c6594819, +4), pvr.vdr.vnsi (5498a8c1, +7), pvr.vuplus (ea3b33f6, +4), pvr.wmc (77af8daf, +4)
  • Includes commits from xbmc/master, ahead +5 (FernetMenta)
  • Exclude [env] kodi-999.10-aarch64-support.patch: Merged upstream
  • Include [env] e7cbe9cb: xf86-video-intel: Explicitely disable TearFree and TripleBuffer
  • Include [env] ed774729: Intel: Implement Passthrough-Range
  • Include [env] 98c65e6a: Kodi: Use Limited Range by default
  • Include [env] patch: xf86-video-intel: bump to 3fafabe
  • Include [env] patch: Fix SIGTERM patch after PR9748
  • Include [env] patch: Fix cmake after PR9750
  • Include [env] patch: Add extra headers needed by 3D BD MVC
  • Include [env] patch: Disable -werror as libnfs won't build 32-bit without it
  • Include [env] patch: Bump libbluray - include MVC support
  • Include [env] patch: Add experimental splash video for RPi
  • Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
  • Include [env] patch: Enable pvr addons, disable pvr updates
  • Include [env] patch: Enable other binary addons
  • Include [env] PR:353: plymouth-lite: add bilinear interpolation patch
  • Include [env] PR:366: mysql: update to 5.7.12
  • Include [env] PR:381: splash: Select splash image based on native resolution
  • Include [env] PR:382: systemd: update to 230
  • Include [env] PR:388: xf86-video-nvidia: update to xf86-video-nvidia-361.42
  • Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
  • Include [pkg] dd81c2f1: [librtmp] Update to 15-Dec-2015 from http://stream-recorder.com/forum/customi...16103.html (kodi)
  • Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
  • Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
  • Include [pkg] patch: drm/i915: Extend Fake HDMI live status to Valley View (linux)
  • Include [pkg] patch: drm/i915/ilk: Wait one vblank before enabling audio (link1, link2) (linux)
  • Include [pkg] patch: drm/i915/psr: Try to program link training times correctly (HSW fix) (linux)
  • Include [pkg] patch: Revert "drm/i915: Exit cherryview_irq_handler() after one pass" (BSW fix) (linux)
  • Include [pkg] patch: CSC: Remove average logic when saving NV12 surface on IVB+ (VAAPI fix) (libva-intel-driver)
  • Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
  • Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
  • Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
  • Include [pkg] PR:9803: [PeripheralCecAdapter] fix playback stopping on screensaver deactivated
  • Include [pkg] PR:9847: [PVR] Feature: Make instant recording behavior configurable
Build Highlights:
  1. NOTE: DVD playback remains temporarily disabled
  2. Bumped xf86-video-nvidia to 361.42
  3. #0523b: Updated xf86-video-nvidia with modesetting fix
  4. #0523b: patch: drm/i915/ilk: Wait one vblank before enabling audio (link1, link2)
Build Details:
  1. LibreELEC.tv:
    • udevil: prevent noobs partitions from auto-mounting (PR:386, 1 commit, 1 file changed)
  2. XBMC:
    • Remove debug log message (PR:9865, 1 commit, 1 file changed)
    • Revert "[addon] binary add-on library rework for API level system" (PR:9843, 11 commits, 476 files changed)
    • PluginDirectory - avoid BusyDialog if not called by main thread (PR:9862, 1 commit, 1 file changed)
    • VideoPlayerVideo: Need to clear pictures before switching decoder (PR:9861, 2 commits, 9 files changed)
    • [tests] Fix some of the issues with the test suite on win32 (PR:9864, 1 commit, 4 files changed)
    • Fix OS X build via CLI make after #9702 (cb22b675)
  3. xbmc/master (FernetMenta):
    • Commits no longer in build:
      • VideoPlayer: drop old workaround in ffmpeg demuxer (8bd4459d)
  4. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] PR:388: xf86-video-nvidia: update to xf86-video-nvidia-361.42
    • Added: [pkg] patch: drm/i915/ilk: Wait one vblank before enabling audio (link1, link2) (linux)
  • 37
  • 38
  • 39(current)
  • 40
  • 41
  • 187
  Thread Closed
  • 11 Vote(s) - 3.91 Average
LibreELEC Testbuilds for x86_64 (Kodi 17.0)3.9111
