Milhouse
Retired Team-Kodi Member
It's a known issue (reported in RPi thread), I'm looking into it - affects Yatse too. Existing connections should work though, only seems to be an issue when creating new connections.
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
what do you mean by existing connections? If I reboot there are no "existing connections" unless you mean preconfigured.
Either way I would say that's not true as none of my remotes from simplecontrol, kodi IOS or even the basic weburl work
Milhouse
It is PR10023, looking into a possible fix.
Milhouse
The iOS/Yatse/etc connection issue will be fixed tonight - thanks all for reporting, and popcornmix for the fix.
awesome thanks for the quick fix!
Will there be a 4.7 version also? Would like to try/test that also on the chromebox - seemed like it was working well for others
Milhouse
I'll do one more 4.7-rc4 build this evening.
Tested several files and all works perfectly (remote repeat and yatse as reported) and no black screen issue or audio profile switch problem
how can we help you for auto repeat bug ?
