2016-06-29, 23:12
Also 4.6.3 still hdmi plugged out error for me
4.7 no error
4.7 no error
(2016-06-29, 22:45)Milhouse Wrote:(2016-06-29, 21:49)Kung-Foo-Kamel Wrote: Hi guys,
Have a weird one here, I have two Identical cherry trail machines, both have fresh installs of Libreelec with the same Milhouse 628 build, one consistently errors when trying to load the WMC PVR add-on and the other does not?? the add on will work but after a reboot it fails to load, I have wiped the system several times and installed builds from 610 and up, all of them do this, the only difference between the systems is one is using HDMI audio out and the other is using USB BOSE audio.
At first I thought it might have been the Test build of the Amber Skin, but even a fresh install with no add ons still results in the PVR add-on failing to load after a reboot.
I have log files from both units here, if you need me to post other logs just let me know what you need, also the 5.1 sound channels are still mixed up with Kernel 4.6.3.
https://1drv.ms/u/s!AmWyHDdgPG0ngZJw2oAuHuihF_kZMg
https://1drv.ms/u/s!AmWyHDdgPG0ngZJxOJE-P2ppJv04_w
Cheers
KFK
1) Test with Estuary. As per the "Skin Usage" section in the first post, please don't report problems unless you can reproduce them with the stock Estuary skin.
Your Amber skin doesn't appear to be compatible with latest Krypton, or the installation is corrupt - there are a ton of skin-related issues being reported in the "System One" log:
Code:16:56:57 351.204620 T:140334486448192 ERROR: unable to load:/storage/.kodi/addons/skin.amber/1080i/DialogConfirm.xml, Line 0
Failed to open file
16:56:57 351.503998 T:140334486448192 ERROR: unable to load:/storage/.kodi/addons/skin.amber/1080i/DialogNotification.xml, Line 0
Failed to open file
16:57:39 393.494446 T:140334486448192 WARNING: CSkinInfo: failed to load skin settings
etc.
2) Check your network configuration - maybe the Amber skin problems are preventing you from seeing notification of errors and warnings or dialogs requesting network information, but there doesn't appear to be a working network available to System One:
Code:16:51:05 12.130283 T:140333753034496 ERROR: CCurlFile::FillBuffer - Failed: Couldn't resolve host name(6)
16:51:06 13.148792 T:140333081945856 ERROR: Exception in thread Thread-1:
File "/usr/lib/python2.7/threading.py", line 801, in __bootstrap_inner
File "/usr/lib/python2.7/threading.py", line 754, in run
File "/storage/.kodi/addons/plugin.video.plexbmc-Krypton/resources/lib/plex/plexgdm.py", line 268, in run_discovery_loop
self.discover()
File "/storage/.kodi/addons/plugin.video.plexbmc-Krypton/resources/lib/plex/plexgdm.py", line 178, in discover
sent = sock.sendto(self.discover_message, self.discover_group)
error: [Errno 101] Network is unreachable
16:51:06 13.150862 T:140333073553152 ERROR: Exception in thread Thread-2:
File "/storage/.kodi/addons/plugin.video.plexbmc-Krypton/resources/lib/plex/plexgdm.py", line 89, in client_update
update_sock.setsockopt(socket.IPPROTO_IP, socket.IP_ADD_MEMBERSHIP, socket.inet_aton(self._multicast_address) + socket.inet_aton('0.0.0.0'))
File "/usr/lib/python2.7/socket.py", line 228, in meth
error: [Errno 19] No such device
3) I can't tell if you're using Amber or not with System Two, as it's not a debug log (neither is System One, but the errors give up more information).
(2016-06-30, 03:24)EricSol Wrote: I been having a problem with highlight or focus for about the last month's worth of builds. For instance, say you go to system/backup and after completing task the focus doesn't return on backup. You assume it's there and say you go to scroll up but the focus is on the menu on the left and you wind up going system/network/connections ect instead of the intended scrolling up to update channel/available versions. The same behavior in youtube, after watching a vid and returning to the list the focus is not on the previously viewed vid untill after a key push so navigation gets screwy. I hope I articulated the problem and any log needed I can provide. Thanks
(2016-06-29, 23:16)Roby77 Wrote: Ok thank you...did you see that my logs are full of lirc error ?
(2016-06-30, 07:57)gjwAudio Wrote: ! YAY !
Remote auto-repeat working again on my 847 NUC !
Thank You to all involved in making this happen
