2016-07-24, 16:28
2016-07-24, 17:19
(2016-07-24, 00:13)Roby77 Wrote: @Milhouse do you plan to add new codec info dialog window to libreelec ?
http://forum.kodi.tv/showthread.php?tid=277344
I won't include the process player info just yet as the code is still being developed and not yet ready for review (so would only generate a lot of noise) - once it's PRd I'll include it.
Edit: Aaaaannnd it's just been PRd... PR10166
2016-07-24, 18:06
(2016-07-24, 03:09)Milhouse Wrote:(2016-07-24, 00:40)Milhouse Wrote:(2016-07-24, 00:13)Roby77 Wrote: @Milhouse do you plan to add new codec info dialog window to libreelec ?
The skin.estuary repo is marked as private on Github and this causes more work to include any pending pull requests in these builds so they'll only be included once they merge. Not really sure why the skin.estuary repo remains private. If they change their mind and make the repo public I'll happily test their pending pull requests.
I still don't see the point of keeping the skin.estuary repo private, however I've implemented a change in the build procedure so that future builds will now be able to access the commits in the skin.estuary private repo. Unfortunately anyone else using my build scripts is unlikely to have access to the skin.estuary private repo (it's limited to Team Kodi members, God knows why) so they'll have to comment out the skin.estuary pull requests.
Thank you!
Edit:great
2016-07-24, 21:09
Hello,
I have a weird problem with the latest build. Sometimes the video freezes but the audio & subtitles keep playing. Is there some setting that I have to adjust?
Platform: Intel NUC Kit DN2820FYKH
NAS: DS415
MYSQL: MariaDB (Synology Version)
I'm using the following cache method:
<cache>
<buffermode>1</buffermode>
<memorysize>314572800</memorysize>
<readfactor>20</readfactor>
</cache>
Thank you for your tips,
Soul
NAS: DS415
<cache>
</cache>
Soul
2016-07-24, 21:20
@Soulplayer: full debug log please. Enable debugging, restart Kodi, reproduce the problem, then "cat /storage/.kodi/temp/kodi.log | pastebinit" and paste the link.
2016-07-25, 00:23
New LibreELEC.tv Krypton build #0724: Generic
(Supercedes previous build)
Based on tip of LibreELEC.tv master (eb89f333, changelog) and tip of XBMC master (bbb264da, changelog) with the following modifications:
# uname -a
Linux NUC 4.7.0-rc7 #1 SMP Sun Jul 24 22:32:58 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160724223031-#0724-geb89f33 [Build #0724]
- Includes FernetMenta "VideoPlayer" patches
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (6d68d212)
- Includes latest libnfs master (fac3a954, ahead +34)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: inputstream.mpd (51271e1a, +23), inputstream.rtmp (7bf2298e), inputstream.smoothstream (99e77711, +4), peripheral.joystick (6090a90e, +1), pvr.argustv (e536f32e), pvr.demo (01c68c88), pvr.dvblink (20e1ccb4, +2), pvr.dvbviewer (7a7ead36, +1), pvr.filmon (efd379b8), pvr.hdhomerun (a71e816d), pvr.hts (66dcb89f, +2), pvr.iptvsimple (21e91a5f, +1), pvr.mediaportal.tvserver (72452b9d, +2), pvr.mythtv (a9ea5816, +6), pvr.nextpvr (32b3c2ff, +2), pvr.njoy (b5d65655), pvr.pctv (12d8baf1), pvr.stalker (b6cb9b87, +9), pvr.vbox (f38f82f0, +2), pvr.vdr.vnsi (8515b4bf, +6), pvr.vuplus (4f2ad621, +2), pvr.wmc (979c37db, +2)
- Includes commits from xbmc/master, ahead +2 (FernetMenta)
- Include [env] e7cbe9cb: xf86-video-intel: Explicitely disable TearFree and TripleBuffer
- Include [env] ed774729: Intel: Implement Passthrough-Range
- Include [env] 98c65e6a: Kodi: Use Limited Range by default
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: Install libbrcmEGL/libbrcmGLESv2 shared libraries, with sym links for backward compatability
- Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
- Include [env] patch: ffmpeg: bump 3.1.1
- Include [env] PR:481: linux: Update to 4.7 (WIP)
- Include [env] PR:526: Cpu temperature readings for devices with aml_thermal interface
- Include [env] PR:535: init: Add upgrade check to avoid incompatible upgrades [RFC,WIP]
- Include [env] PR:555: Package updates
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
- Include [pkg] patch: drm/i915: Extend Fake HDMI live status to Valley View (linux)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] PR:171: fix seeklabel (kodi-theme-Estuary)
- Include [pkg] PR:172: add player process and pvr signal info (kodi-theme-Estuary)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:9803: [PeripheralCecAdapter] fix playback stopping on screensaver deactivated
- Include [pkg] PR:10141: set tvshow thumb on *all seasons node
- Include [pkg] PR:10157: [WIP] Double the backslash in mysql in case we're in 'LIKE'
- Include [pkg] PR:10164: AE: add atempo filter
- Include [pkg] PR:10166: Readd Player process info and PVR info dialog
- AE: add atempo filter (PR10164)
- PlayerProcessInfo dialog. This is accessed by the "o" key on a keyboard, "<title>" button on a remote.
Add the following entries to your keymap if you require a custom/alternative mapping (replace "<button>" and "</button>" with your own button name, ie. "<record>" and "</record>" etc.)
Code:<keymap>
<FullscreenVideo>
<remote>
<button>PlayerProcessInfo</button>
</remote>
</FullscreenVideo>
<PlayerProcessInfo>
<remote>
</remote>
</PlayerProcessInfo>
</keymap> - Fix seeklabel (see comment)
- LibreELEC.tv:
- Regain SPDIF passthrough on imx hardware with "old" kernel (PR:558, 2 commits, 1 file changed)
- XBMC:
- [cmake/linux] Move WiiRemote target to ExtraTargets.cmake (PR:10159, 1 commit, 2 files changed)
- [PeripheralCecAdapter] fix broken standby after … (PR:10139, 1 commit, 1 file changed)
- Move win32 files to their own platform folder (PR:10124, 1 commit, 66 files changed)
- AESinkAudiotrack: Do not average over 4 seconds but 200 ms (PR:10161, 1 commit, 1 file changed)
2016-07-25, 15:33
Have you tried this build on your Revo? Can't play any music on mine and it seems to be ignoring my keyboard.xml.
Will get a debug log later when I have the time.
2016-07-25, 18:58
(2016-07-25, 15:33)Hitcher Wrote: Have you tried this build on your Revo? Can't play any music on mine and it seems to be ignoring my keyboard.xml.
I can reproduce the music problem - it hangs Kodi. Same on RPi2 so not Revo or Generic/x86 specific.
This is the debug log when playing music: http://sprunge.us/bNjM
There is no crash, as Kodi simply freezes (some kind of deadlock?), but this is the crashlog when I kill kodi.bin: http://sprunge.us/fTfF
I'll try testing a build without the AE tempo filter and see if that makes any difference.
No idea about the keyboard.xml, typo perhaps?
2016-07-25, 20:08
Music playback is working after dropping PR10164 (AE: add atempo filter) so I won't include that in future builds until there is a fix.
2016-07-25, 23:03
New LibreELEC.tv Krypton build #0725: Generic
Based on tip of LibreELEC.tv master (6a1e71a4, changelog) and tip of XBMC master (2b8e2041, changelog) with the following modifications:
# uname -a
Linux NUC 4.7.0 #1 SMP Mon Jul 25 21:08:36 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160725210638-#0725-g6a1e71a [Build #0725]
- Includes latest addons: inputstream.mpd (51271e1a, +23), inputstream.rtmp (7bf2298e), inputstream.smoothstream (99e77711, +4), peripheral.joystick (6090a90e, +1), pvr.argustv (e536f32e), pvr.demo (01c68c88), pvr.dvblink (20e1ccb4, +2), pvr.dvbviewer (7a7ead36, +1), pvr.filmon (efd379b8), pvr.hdhomerun (a71e816d), pvr.hts (66dcb89f, +2), pvr.iptvsimple (21e91a5f, +1), pvr.mediaportal.tvserver (72452b9d, +2), pvr.mythtv (d10d210b, +8), pvr.nextpvr (32b3c2ff, +2), pvr.njoy (b5d65655), pvr.pctv (12d8baf1), pvr.stalker (b6cb9b87, +9), pvr.vbox (f38f82f0, +2), pvr.vdr.vnsi (8515b4bf, +6), pvr.vuplus (4f2ad621, +2), pvr.wmc (979c37db, +2)
- New 4.7.0 kernel
- Drop PR10164 AE: add atempo filter - music plays now
- Drop freetype bump from PR:555 - Chromium should be working again
- LibreELEC.tv:
- Sapphire Remote driver addon (PR:561, 2 commits, 8 files changed)
- Package updates (PR:555, 18 commits, 21 files changed)
- mysql: update to 5.7.13
- ccache: update to 3.2.7
- gettext: update to 0.19.8.1
- gmp: update to 6.1.1
- pcre: update to 8.39
- swig: update to 3.0.10
- libpng: update to 1.6.23
- llvm: update to 3.8.1
- bluez: update to 5.41
- xorg-server: update to 1.18.4
- busybox: update to 1.25.0
- fuse: update to 2.9.7
- libevdev: update to 1.5.2
- procps-ng: update to 3.3.12
- libinput: update to 1.4.0
- fontconfig: update to 2.12.0
- libgpg-error: update to 1.24
- libdrm: update to 2.4.70
- XBMC:
- pvr.mythtv:
- 4.7.0 (PR:72, 2 commits, 9 files changed)
2016-07-25, 23:34
Rolled back to #0721 to get my keymap.xml working again. I think it might be this commit that is causing me problems as I use the Amazon Fire TV stick remote -
eventlircd: Add support for Amazon Fire TV Stick Bluetooth remote
2016-07-26, 00:31
(2016-07-25, 23:34)Hitcher Wrote: Rolled back to #0721 to get my keymap.xml working again. I think it might be this commit that is causing me problems as I use the Amazon Fire TV stick remote -
I copied the file /usr/lib/udev/rules.d/98-eventlircd.rules to /storage/.config/udev.rules.d/98-eventlircd.rules and edited it removing the new code
http://pastebin.com/KAVyX7Tr
This allows me to use my custom keyboard.xml with the aftv remote
2016-07-26, 02:39
(2016-07-25, 23:03)Milhouse Wrote: New LibreELEC.tv Krypton build #0725:
[*]Drop freetype bump from PR:555 - Chromium should be working again
Confirm Chromium working again thanks.
2016-07-26, 07:48
(2016-07-26, 00:31)porkchop999 Wrote:(2016-07-25, 23:34)Hitcher Wrote: Rolled back to #0721 to get my keymap.xml working again. I think it might be this commit that is causing me problems as I use the Amazon Fire TV stick remote -
I'm going to try later and see if it's simply a case of changing the values over.
ie
<key id="61952">Info</key>
should now be -
<KEY_MENU>Info</key>
or -
<KEY_TITLE>Info</key>
2016-07-26, 13:29
(2016-07-22, 23:04)fritsch Wrote: TrueHD is broken, yes - but it has no priority right now. If you don't want it forgotten, open a trac.fyi: http://trac.kodi.tv/ticket/16819
