2016-09-08, 18:02
Not sure if these builds are going to be any different with your RX460, but once you've booted into 7.90.005 (xorg error or not) you should be able to use ssh or samba to copy in one of these test builds and reboot.
(2016-09-08, 18:02)Milhouse Wrote: Not sure if these builds are going to be any different with your RX460, but once you've booted into 7.90.005 (xorg error or not) you should be able to use ssh or samba to copy in one of these test builds and reboot.
(2016-09-08, 19:31)madmarkym Wrote: If I am getting the xorg error how would I enable ssh as I thought it needs enabling from within kodi. I was hoping if I could get into ssh maybe I could install the Linux drivers for my rx460 ,manually. Would it be the Ubuntu v14 or 16 that I would need to use if I got that far?
(2016-09-08, 20:10)Boulder Wrote: I have two issues appearing:
1) In TV Shows, I cannot enable subtitles as default for all media. The next episode I try always has subs disabled. It seems to work with Movies though.
2) In TV Shows, at least with my 10-bit HEVC encoded files don't have "Auto" in the deinterlacing settings. The files are encoded as progressive so I'd really like to use Auto instead of setting Off as default.
Debug log here: http://pastebin.com/XnZ5H6VB
(2016-09-08, 20:10)Milhouse Wrote:(2016-09-08, 19:31)madmarkym Wrote: If I am getting the xorg error how would I enable ssh as I thought it needs enabling from within kodi. I was hoping if I could get into ssh maybe I could install the Linux drivers for my rx460 ,manually. Would it be the Ubuntu v14 or 16 that I would need to use if I got that far?
Add "ssh" to the end of your kernel config in syslinux.cfg or extlinux.cfg to enable ssh. Samba should be enabled by default (if not, that's a cock up). You won't be able to install any drivers.
# uname -a
Linux NUC 4.7.3 #1 SMP Fri Sep 9 04:16:20 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160909041503-#0908-g3c47494 [Build #0908]
(2016-09-08, 22:34)madmarkym Wrote: I managed to install the latest update, but unfortunately the xorg error remains, so it looks like this graphics card is useless for the time being.
(2016-09-08, 17:48)madmarkym Wrote: I attempted to install LE 7.90.005 which I needed as a base install before I could add the latest Milhouse update.
The problem was that it would not recognize my graphics card and I got the error 'failed to start xorg'
I am using a Radeon RX460.
(2016-09-08, 22:34)madmarkym Wrote:(2016-09-08, 20:10)Milhouse Wrote:(2016-09-08, 19:31)madmarkym Wrote: If I am getting the xorg error how would I enable ssh as I thought it needs enabling from within kodi. I was hoping if I could get into ssh maybe I could install the Linux drivers for my rx460 ,manually. Would it be the Ubuntu v14 or 16 that I would need to use if I got that far?
(2016-09-09, 07:51)fritsch Wrote: @alxtr1bal: Include [pkg] patch: xf86-video-amdgpu: Latest commits (6a1ba04) adding Polaris 10 & 11 support (xf86-video-amdgpu) <- such commits are highly relevant for you.
Next time, please gather logfiles. Xorg.0.log and dmesg | pastebinit
With these we can file bugs at bugs.freedesktop.org so that this gets fixed. It won't happen magically.
(2016-09-09, 05:41)Milhouse Wrote:(2016-09-08, 22:34)madmarkym Wrote: I managed to install the latest update, but unfortunately the xorg error remains, so it looks like this graphics card is useless for the time being.
Try build #0908, this includes updated AMD GPU support (including Polaris 10 & 11).
