I think one of the things also needed is to have Kodi to be able to Switch Resolution base on the file types you player, this feature is already supported in Andriod( tested Himedia Q10 Pro) this will help 3D MVC playback.
If the Resolution is set to 3840X2160 3D MVC playback doesn't work and HDR support.
PS: The ASRock Beebox-S KabyLake will be released November 15th.
MY CURRENT MEDIA PLAYER |
MY HOME THEATER
MINIX NEO U22-XJ COREELEC v19 MATRIX | EGREAT A10 | NVIDIA SHIELD | LG 75 NANO90 DV/HDR+ | Sony 43 Android TV HDR
XBOX SERIES X | PS4 PRO 4K | JBL 9.1 System 5.1.4 DTS:X/ATMOS
True! lol.
Same thing in my eyes, small form factor PC?
My Beebox-s 7100 box arrived yesterday. I have everything installed today. In principle it works great.
3D MVC and 10 bit works with the HDMI 1.4 port. 4k Hevc movies Up to 30hz works with the hdmi 1.4 port as well. If you want to watch 4k movies with 50 or 60 fps you need to use the hdmi 2.0 port. Unfortunately 3D doesn't work with the hdmi 2.0 port and you also can't connect your tv or receiver with both ports at the same time. If you do the movie output over the hdmi 1.4 port stutters.
So HDMI 1 (4K/2K@60Hz) port can't do 3D MVC? Seems odd... did you switch resolution to 1080p for 3D?
[H]i-[d]eft [M]edia [K]een [V]ideosaurus
My HT
