2016-10-19, 17:48
Thought I will start a new thread with the released of a few of Intel Kaby Lake Hardware.
Specs!
Intel Kaby Lake
MSI Cubi2-007BUS
Specs
GB-BKi3HA-7100
GIGABYTE BRIX GB-BKi3HA-7100 Specs
Asrock Beebox-S Series
(L3).jpg)
GIGABYTE BRIX GB-BKi3HA-7100and MSI CUBI 2 are the only Barebone that i seeing available, the MSI Cubi2-007BUSis available to purchase.
INTEL NUC KABY LAKE
INTEL NUC Kaby Lake will be released during the CES 2017 (January 5-8). The i3 NUC will be available in January, i5 in February and i7 finally in March.
Specs!
Intel Kaby Lake
Quote:-
Graphics Specifications
Processor Graphics ‡ Intel® HD Graphics 620
Graphics Base Frequency 300.00 MHz
Graphics Max Dynamic Frequency 1.00 GHz
Graphics Video Max Memory 32 GB
Graphics Output eDP/DP/HDMI/DVI
4K Support Yes, at 60Hz
Max Resolution (Intel® WiDi)‡ 1080p
Max Resolution (HDMI 1.4)‡ [email protected]
Max Resolution (DP)‡ [email protected]
Max Resolution (eDP - Integrated Flat Panel)‡ [email protected]
Max Resolution (VGA)‡ N/A
DirectX* Support 12
OpenGL* Support 4.4
Intel® Quick Sync Video
Yes
Intel® InTru™ 3D Technology Yes
Intel® Clear Video HD Technology Yes
Intel® Clear Video Technology Yes
Intel® Wireless Display Yes
Quote:Supporting the Newest Standards in Multimedia
GIGABYTE ensures users won’t be limited by the standards or connections on the BRIX, by including HDMI 2.0 and support for HDCP 2.2* users can rest assured that their device will be able to display content to its full potential. The BRIX supports native resolutions of 4K at 60Hz, presenting unrivaled visual clarity and stunning realism to owners of UHD displays.
* HDMI port support HDMI 2.0 and HDCP 2.2.
Quote:As measured by Windows® 10 1080p 24fps Local Video Playback Test. USB devices disconnected, local WiFi access connected, screen brightness 200 nits. Launch Tears of Steel (1080p H264 10MBps 24fps) video using the Windows* Movie & TV App. Measure and calculate average power for the duration of the video.
Estimated on Intel® Core™ i7-7500U Processor, PL1=15W TDP, 2C4T, Turbo up to 3.5GHz, Memory: 2x4GB DDR4-2133, Storage: Intel® SSD, Display Resolution: 25x14, Intel® HD Graphics 620, OS: Windows® 10 TH2. Battery size 42 WHr.
3
As measured by Windows® 10 4K 24fps 10bit HEVC Local Video Playback Test. USB devices disconnected, local WiFi access connected, screen brightness 200 nits. Launch Tears of Steel (4K H265 24fps) video using the Windows* Movie & TV App. Measure and calculate average power for the duration of the video.
Estimated on Intel® Core™ i7-7500U Processor, PL1=15W TDP, 2C4T, Turbo up to 3.5GHz, Memory: 2x4GB DDR4-2133, Storage: Intel® SSD, Display Resolution: 4K, Intel® HD Graphics 620, OS: Windows® 10 TH2. Battery size 66 WHr.
MSI Cubi2-007BUS
Specs
Quote: Windows 10 Home - MSI recommends Windows 10 Pro
DDR4 2133HMz up to 32GB
7th Intel® Kabylake-U power saving processor
Equipped with USB3.1 Gen1 type C
Maximum to 1 x M.2 SSD and 1 x 2.5” SATA HDD or SSD
Supports 4K ultra-high definition resolution
Supports Dual monitors
Supports super charger
Supports 802.11ac Combo Card
Supports standard VESA-mount
Expand connectivity and storage with the detachable bottom case
GB-BKi3HA-7100
Quote:Features Latest Intel® 7th generation Core Processors
Ultra compact PC design at only 0.6L (46.8 x 112.6 x 119.4mm)
Supports 2.5” HDD/SSD, 7.0/9.5 mm thick (1 x 6 Gbps SATA 3)
1 x M.2 SSD (2280) slot
2 x SO-DIMM DDR4 slot (2133 MHz)
Intel® IEEE 802.11 ac ,Dual Band Wi-Fi & Bluetooth 4.2 NGFF M.2 card
2 x USB3.1 (1* USB Type-C™)
2 x USB 3.0
HDMI 2.0
HDMI plus Mini DisplayPort Outputs (Supports dual displays)
Intel Gigabit lan
Headphone/Microphone Jack
VESA mounting Bracket (75 x 75mm + 100 x 100mm
(L3).jpg)
Quote: Powered by the Intel® 7th Generation Intel® Core Processors
Support DDR4 2133 MHz, 2 x SO-DIMM slots, Max. 32GB
Hyper speed WiFi 802.11ac, also works as a wireless access point
Supports two storage devices for added flexibility (1 x 2.5" SATA3 HDD + 1 x M.2)
Supports Dual Monitor (2 x HDMI or HDMI+Full DisplayPort)
Smooth and ultra high resolution 4K/2K/60Hz playback
The world's first NUC paired with an USB 3.1 Gen2 Type-C port
A free bundled remote controller for controlling your PC wirelessly
Offers rich features in a tiny 0.6L package
IR Sensor Window
According to the Manual 1 HDMI support (4K/[email protected]) and the other one support (4K/[email protected])
INTEL NUC KABY LAKE
Quote:Shared specifications
Let’s first have a look at what is common for all of the NUCs.
Memory: Dual-channel DDR4L-2133, max. 32 GB
Display Connectivity: HDMI 2.0 port (4k 60Hz support, via LSPCon), DP 1.2 via USB type-C
M.2: Single M.2 slot capable of accepting a 2280 or a 2240-sized SSD
SATA: Single slot for a 2.5″ SATA drive (not present in the compact NUC7i3BNK and NUC7i5BNK)
Card reader: Inbuilt Micro SDXC card reader
Networking: Intel Gigabit Ethernet and Intel Wireless-AC 802.11ac network adapters, Bluetooth 4.2
USB ports: 2 USB 3.0 ports in the front (one with fast charging), 2 USB 3.0 ports in the rear, 1 USB 3.1 Type-C port in the rear, Dual-USB 2.0 header on mainboard
Other: Consumer infrared receiver, user-customizable ring LED in the front face, HDMI CEC support…
Core i3 Model (NUC7i3BNH & NUC7i3BNK)
CPU: Intel Core i3-7100U, dual-core, hyperthreading, 15W TDP, 2.4 GHz
GPU: Intel HD Graphics 620 (GT2), 24 EUs, 300 MHz base frequency, 1.0 GHz max frequency
Core i5 Model (NUC7i5BNH & NUC7i5BNK)
CPU: Intel Core i5-7200U, dual-core, hyperthreading, 15W TDP, 2.5 GHz, Boost up to 3.1 GHz
Thunderbolt 3 via the USB Type-C port
Core i7 Model (NUC7i5BNH)
CPU: Intel Core i7-7567U, dual-core, hyperthreading, 28W TDP, 3.3 GHz, Boost up to 3.6 GHz
GPU: Intel Iris Graphics 650 (GT3e), 48 EUs, 300 MHz base frequency, 1.1 GHz max frequency
No compact chassis model available (due to cooling requirements)
