jpeg73
Junior Member
I do the following
from #714 -> #0518x result KO
from #0518x -> #0628x result KO
from #0628x -> #713 result OK
Any test to advice ?
Regards
JP
Quick post here likely missing important info, so quite possibly useless. But while it's on my mind, here it is.
Up until a couple days ago I was running two systems, both on stable version of LibreELEC. One is on a Chromebox, the other is on a VM on my unRAID Server @ 4 MB RAM & 4 Cores.
I updated the Chromebox to #0903. No issues for my uses outside of the HDHR addon no longer working properly. The "thinking" rotating clock, and then logo were stuck on the screen and there wasn't anything I can do. No biggie as I rarely use this addon, only if the MythTV PVR backend is failing for whatever reason and I don't have time to reset it. I was able to install Netflix and Amazon Prime. Big plus.
Today, I did the upgrade to the VM. After the reboot, it was sluggish and unusable. Navigating the menu was clunky, a second or more behind, and videos would not stream properly. I realized I had installed #0906. I figured it was something with the VM not working well on these Alpha versions, but I decided to try again by downgrading to #0903, the working version on my Chromebox. To my pleasant surprise, it worked.
If there's any diagnostic logs you'd like me to run, or tests to try out, I'll keep my eye on this thread.
Milhouse
Retired Team-Kodi Member
@Living Legend can you test #0904 and #0905 to determine if they're also affected with the same sluggish performance? The obvious candidate would be #0904 with the new 4.13 kernel, though I've no idea why...
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
running 0907 build
renders the interface unusable on my hardware.
regarding interface build 0904 still works
as of 09XX build the addon game.libretro is no longer compatible
can I fix this somehow?
Øyvind
Junior Member
Hi Milhouse,
seit #905 - #907 große Performance Probleme, ein CPU Kern immer mit 100% ausgelastet. #904 OK
since # 905 - # 907 great performance problems, a CPU core always loaded with 100%. # 904 OK
top - 19:23:22 up 14 min, 1 user, load average: 1.08, 1.02, 0.69
Tasks: 96 total, 2 running, 93 sleeping, 0 stopped, 1 zombie
%Cpu(s): 49.8 us, 0.8 sy, 0.7 ni, 48.7 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
KiB Mem : 3199624 total, 2007232 free, 374944 used, 817448 buff/cache
KiB Swap: 0 total, 0 free, 0 used. 2527980 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
665 root 20 0 1933336 377340 77988 R 102.0 11.8 14:45.00 kodi.bin
202 root 20 0 33728 4548 4188 S 0.3 0.1 0:00.57 systemd-journal
513 root 20 0 127564 15868 10584 S 0.3 0.5 0:06.81 Xorg
1 root 20 0 20240 5796 4568 S 0.0 0.2 0:01.19 systemd
2 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kthreadd
3 root 20 0 0 0 0 S 0.0 0.0 0:00.54 kworker/0:0
4 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/0:0H
5 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kworker/u8:0
6 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 mm_percpu_wq
7 root 20 0 0 0 0 S 0.0 0.0 0:00.16 ksoftirqd/0
8 root 20 0 0 0 0 S 0.0 0.0 0:00.08 rcu_sched
9 root 20 0 0 0 0 S 0.0 0.0 0:00.00 rcu_bh
10 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migration/0
11 root rt 0 0 0 0 S 0.0 0.0 0:00.00 watchdog/0
12 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/0
13 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/1
14 root rt 0 0 0 0 S 0.0 0.0 0:00.00 watchdog/1
15 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migration/1
16 root 20 0 0 0 0 S 0.0 0.0 0:00.14 ksoftirqd/1
17 root 20 0 0 0 0 S 0.0 0.0 0:00.43 kworker/1:0
18 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/1:0H
19 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kdevtmpfs
20 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 netns
22 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kworker/0:1
23 root 20 0 0 0 0 S 0.0 0.0 0:00.00 khungtaskd
24 root 20 0 0 0 0 S 0.0 0.0 0:00.00 oom_reaper
25 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 writeback
26 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kcompactd0
27 root 39 19 0 0 0 S 0.0 0.0 0:00.00 khugepaged
28 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 crypto
29 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kblockd
30 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 ata_sff
31 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 rpciod
32 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 xprtiod
33 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kswapd0
34 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 nfsiod
35 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 cifsiod
36 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 cifsoplockd
66 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 acpi_thermal_pm
67 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 ttm_swap
69 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 knbd-recv
70 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 iscsi_eh
71 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 nvme-wq
72 root 20 0 0 0 0 S 0.0 0.0 0:00.00 scsi_eh_0
73 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 scsi_tmf_0
74 root 20 0 0 0 0 S 0.0 0.0 0:00.00 scsi_eh_1
