2018-01-06, 09:04
I was reading that CuVid would improve Nvidia support, is this anywhere in the pipe?
(2018-01-05, 14:14)sappypappy Wrote:(2018-01-05, 00:21)Milhouse Wrote:(2018-01-04, 23:17)sappypappy Wrote: US here, but maybe some titles match up. I've tried a bunch of randoms, but can you give me the specific videos you've played that have been displaying in 1080p? I'll try them on my end & see if we can't find the source of this obvious bug (could be in the add-on, could be in Kodi, or a combo of the two fighting somewhere along the line).
While I haven't seen 1080p yet, I have noticed some play in way low res, some in 720p (but never above that).
Netflix Originals > A Series of Unfortunate Events > Season 1 > Episode 1 plays for me in 1080p (as do other episodes of this tv show).
Thank you! Tried it & its serving up 1280x720 exactly. Went ahead & did some more troubleshooting by ditching WiFi for Ethernet & hooking up to a straight 1080p TV monitor thinking there might be a glitch in either. No change. Grrr.
Since others are getting better quality streams running the same generic builds (using the same install methods AFAIK), and after the tests I've ran, only thing I can imagine is some kind of hardware hangup regarding either the add-ons themselves or the beta builds not working 100% with my 5th gen i3 NUC. I notice transcoding Plex (running latest PMC inside Kodi) takes a hell of a lot of CPU resources now (almost maxed out) when it shouldn't. Just with basic 1080p h264 videos.
I'm about to run the same setup on my Android TV (Mi Box) to see what that does. Will report back for anyone interested.
(2018-01-05, 19:57)TimoJ Wrote:By accident. I will fix this(2018-01-03, 20:14)TimoJ Wrote:Looks like commits 29th Dec by @FernetMenta made non-linear stretch setting disappear. Is this by design and this feature is now gone or is it a bug?(2017-12-31, 10:46)TimoJ Wrote: Where did non linear stretch go? It's missing from few latest builds.Anyone? Build 1228 was the last one where it was available. What happened?
(2018-01-06, 06:46)mike77 Wrote: Hi Milhouse,
Could you update alsa-lib to v1.5.0 , there are some changes and audio should work on cherry trail devices.
(2018-01-06, 15:08)Milhouse Wrote:Yes, my mistake. 1.1.5 is correct version(2018-01-06, 06:46)mike77 Wrote: Hi Milhouse,
I've bumped alsa-lib (and alsa-utils) to the latest available 1.1.5 (up from 1.1.4) - you might need to wait a few more years for 1.5.0...
I've also bumped pulseaudio to 11.1 - this should all be in tonight's #0106 build.
(2018-01-06, 02:53)yabba235 Wrote: Hi !
I trying enable HD audio bistream over hdmi in my mini pc Zotac mi553, but without success.
Only work ac3/dts bitream and lpcm. But it is not enough for eg. Atmos or DTS:X.
I use last build #0105 and more another but unlucky.
My setup is zotac mi553 hdmi out or dp/hdmi adapter out. and Marantz nr1601.
(2018-01-06, 15:29)yabba235 Wrote: Millhouse VERY BIG THANK'S for new build #0105 - now on my Zotac MI553 works bitstream DTS HD MA & TrueHD !!
Ii hope Atmos & DTS:X works too ( I waiting for new receiver )
(2018-01-06, 02:53)yabba235 Wrote: Milhouse - any yours build incude HBR patch ?Yes.
(2018-01-05, 11:41)Milhouse Wrote:I have uploaded LibreELEC 8.2.2 and I often have a sound problem on it. The sound sometimes distorts. Suddenly, he slows down for a second and returns to normal. Your new builds are the same. I have an intel lake frog. There is no problem in movies. The problem is only on LIVE TV.(2018-01-05, 09:14)kowalmisiek Wrote: Are there works in the new kodi on the sound being played on TV channels? ( distorted )
Can you explain in a little more detail - I don't understand your question.
(2018-01-07, 00:04)kowalmisiek Wrote: I have uploaded LibreELEC 8.2.2 and I often have a sound problem on it. The sound sometimes distorts. Suddenly, he slows down for a second and returns to normal. Your new builds are the same. I have an intel lake frog. There is no problem in movies. The problem is only on LIVE TV.
fe6778c0bafadc1af4b7e9b57083555ec5c77d604e5968e5e0123722fb2ed825
(Generic)text:# uname -a
Linux NUC 4.14.10 #1 SMP Sat Jan 6 22:00:21 GMT 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180106215729-#0106-g6271a29 [Build #0106]
# Kodi version
(18.0-ALPHA1 Git:138fa39). Platform: Linux x86 64-bit
(2018-01-07, 13:48)snowderer Wrote: Hi I installed libreelec 8.2.0 upgraded to your latest and updated to your latest build. Unfortunatly I can`t get retrogaming to work... When I try to install Libretro Compatibility Addon I get an Error with failed dependencies. Any Hint what can be wrong ?
