2018-02-27, 22:22
No - those settings do not exist, whatever your problem is has nothing to do with them.
(2018-02-27, 23:04)Mitch23 Wrote: Problem only exist on LE 9.0 (Zotac ZBOX ID84 and an Intel NUC7i3BNH).
Latest Windows developer build is working (uses the same tvheadend server).
38de91521e596d6fedff0bd416868e4dc173619c7292cc1e22bdeca4c45dbe9b
(Generic)text:# uname -a
Linux NUC 4.14.22 #1 SMP Tue Feb 27 21:19:00 GMT 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180227211652-#0227-g68cbae3 [Build #0227]
# Kodi version
(18.0-ALPHA1 Git:d9c810b). Platform: Linux x86 64-bit
(2018-02-27, 15:45)rudrood Wrote: When watching PVR the progressbar on the OSD is working oke for the first program. But when the next program starts it remains full and doesn't reset.
Happening with the latest Kodi Leia builds (not sure when it started) and plain and modded Estaury skin.
https://imgur.com/a/hn1w9
screenshots are made with Estaury mod skin, but with plain Estaury it is the same.
First image: watching first show (progressbar is oke)
Second image: next program has started but the progressbar remains filled from the previous program.
Does it make sense to post logs or find out when problem started (difficult cause I have to wait for special moment)?
(2018-02-26, 21:39)fritsch Wrote:Have you seen my sample? Do you need anything else to be able to help me?(2018-02-26, 18:04)MaxMustermann Wrote:Could you please post a sample?(2018-02-26, 12:44)basco Wrote: I can also confirm the black artefacts are gone. thanks guys!!I'm still having the artifacts. It's noticeably better with 'limited color range' turned on, but the artifacts are still there.
Here are some images and the log file. I hope you can find a fix. #0205 was the last version without artifacts.
(2018-02-28, 16:45)MaxMustermann Wrote:Yes. yol tested it - works perfectly fine, no black artifacts at all. He tested on AMD. I tested on Intel.(2018-02-26, 21:39)fritsch Wrote:Have you seen my sample? Do you need anything else to be able to help me?(2018-02-26, 18:04)MaxMustermann Wrote: I'm still having the artifacts. It's noticeably better with 'limited color range' turned on, but the artifacts are still there.Could you please post a sample?
(2018-02-27, 11:50)basco Wrote:But it also appeared from #0206 on like with others having this issue (e.g. this post). Maybe it depends more on the model of the graphic card.(2018-02-26, 22:02)MaxMustermann Wrote: OK. SampleI don't see any **black** artifacts.
Probably not related to the black artefacts issue.
(2018-02-24, 13:53)fritsch Wrote:I added loglevel=2 into advancedsettings.xml(2018-02-24, 13:28)kalle2000 Wrote:Debug Log was not enabled when kodi was starting up, therefore no information in the logfile available.(2018-02-24, 12:28)fritsch Wrote: No it's not. Your HDMI is a DP converter bridge an lspcon.Ok, thanks for the explanation.
Still the question is: why are some resolutions not shown in kodi v18?
906633d4814c3b04c3f711bfc07963f75f1185d46f54d4df4bb718afa9486de4
Linux NUC 4.14.22 #1 SMP Wed Feb 28 21:17:25 GMT 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180228210338-#0228-g1eb0ca9 [Build #0228]
# Kodi version
